sorcerer
- Preston, Lancs, UK
Got an HP Compaq DX2420 desktop machine in that was originally running Vista but was upgraded a while ago (not by me) to Windows 7 Home Premium 32-bit. It's got 2GB RAM and a Pentium Dual Core E5200 @ 2.5GHz and is running, according to the customer, "slower than normal".
It had one or two viruses/malware but is now clean. It's not overheating, RAM test shows no errors after an 11-hour run with Memtest86+ v5, and both GSmartControl and WD Data Lifeguard diagnostics report no errors after running extended tests on the HDD.
Rightly or wrongly I've tended to discount the HDD as the problem if GSmartControl and/or the manufacturer's diagnostics come up clean but a recent mention of response times somewhere made me think I should also look into that. I ran both HDD Scan and the trial version of HDD Tune, the results of which can be seen here, here and here. The problem is, as I've not really used either program before I don't really know what I'm looking at or how to interpret the results, so could some kind soul please advise if the HDD is in fact good or if you would be replacing it? Thanks.
