Mr.Mike
- San Diego Area
Hello All:
The Machine:
Dell XPS 400
2.8 Ghz Intel Processor
1 Gb Ram Unbuffered
250 Gb Sata HDD (Samsung SP2504C)
OS: XP SP3 (media addition)
Startup: After Splash screen, a message reads:
Checking file system on C:
The type of the file system is NTFS
The volume is dirty.
CHKDSK is verifying giles (stage 1 of 3)
File verification completed
CHKDSK is verifying indexes (stage 2 of 3)
Index verification completed
CHKDSK is verifying security descriptors (stage 3 of 3)
Security descriptor verification completed.
And there it HANGS
Tried Boot From CD:
Attempted to run the Recovery Console in Win Setup from an OEM CD and the UBCD4Win CD. I get the following message:
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.
I can however, boot to the UBCD4Win and get that environment which doesn't seem equipped to solve my problem.
I have pulled and reconnected the HDD, tested and reseated the RAM, and checked all other connections. I have replaced the SATA data cable and the switched power connector to another one. Still the message above shows up.
Next I went into the Boot Menu (F12) and ran Hard Drive Diagnostics.
Test showed:
Drive 0: Samsung SP2504C - Fail. Return Code: 7
--Reason Code JP8YLB1P@aH
My research shows this could be due to multiple power interrupts caused by power failures and improper shutdowns. The owner has since verified this (no proper shut down). Samsung and Dell forums refer to this code as a "failed HDD".
I then tried to boot into safe mode and although it initially looked as if it would, the black screen hangs with multiple lines showing:
multi(0)disk(0)rdisk(0)pertition(2)\windows\system 32\DRIVERS\*****.sys
My conclusion:
Unless there is something that will prevent this, I will slave it and try to extract data to another HDD. Otherwise the boot sector is blasted and is probably not fixable.
Any thoughts? I appreciate any an all responses.
Scarlet Pathos
The Machine:
Dell XPS 400
1 Gb Ram Unbuffered
And there it HANGS
Tried Boot From CD:
Test showed:
My conclusion:
Scarlet Pathos
