Good PSU for testing purposes?
That is way more than adequate.
460W
1 x Main connector (20+4Pin)
1 x 12V(8Pin)
3 x peripheral
4 x SATA
1 x Floppy
1 x PCI-e
and dual +12 rails
(I should have this in my bench machine and use its crappy PS for testing.)
Get yourself one of these Testers too.
99-887-004-S01
The CM 460 Elite is a premium power supply, I use one in my gaming rig and its rock solid.
I wouldn't use it for testing (overkill) any generic 12$ ATX PS should fit that bill, just check the rails beforehand to make sure they are in spec.
No, I'd stick with the Elite 460, nothing is more stable or quiet at that price point.
I have 3 Coolermaster 460 Elites on my shelf, I use them for servers or when I build gaming rigs for clients, I've never had one come back.
In theory, a dual rail ps provides increased stability since the different components that draw power from the 12v rails do so at varying voltages. Dual rails will allow for a "balance" of the current draw so as to protect against a rail being unable to meet the neccessary output. In a nutshell, it should provide increased stability and safety, while running cooler since the rails won't be drawing as much power as a single rail.
Here's an interesting article on Single vs Dual Rails from another site. http://www.jonnyguru.com/forums/showthread.php?t=3990
I think the cooler master is a good choice.
I have generally bought the thermaltakes that are on sale @ newegg for testing\spare purposes.
However for replacing and myself, I use mostly OCZ, PC Power & Cooling, Corsair or Seasonic.
great info. it's not only the dual rails but the amps on the rails that makes a good power supply. and it's highly debated that two rails is better or more stable than one and I believe that is the reason you said in theory.
