Wilkins IT Solutions
- Oshawa, ON
Hey there,
I have been trying to get my Windows 7 Home machine to allow hot swappable on my Sata harddrive. I just built a new system using ASUS M5A88-M with an AMD FX8120 and have an OCZ SSD for the main drive and a Seagate Barracude 2TB 6Gbps as a storage drive. The case i got is a Silverstone GD06 and has two drive bays that you can add and remove harddrives from. They plug directly into the sata controller on the Motherboard. I have tried just about everything to get them working.
I installed the OS with AHCI enabled on all ports. The msachi drivers are installed and both harddrives work. I did not find any compatibility issues with the mobo or hdd with being hot swappable. I have tried editing the registry, i tried the app "HotSwap" all to no avail.
The SATA Dvd drive is able to be "Safely Removed" so i know the AHCI controller is working right, I just cannot get the SATA drive to be removeable. The end goal of this is to get the second bay to have another harddrive in it and use that as the storage i was just trying to get the Seagate to remove so i know the system works.
Thanks for any advice you can give tech's!
Alex
Alex
