Freeware partition resizer and mover
lan101
Stumbled across this freeware tool tonight. Works very well. All these tools out there now want all this subscription money for something that I need like 2 or 3 times a year lol. Figured I'd share if anyone needed it.
I've had no reason to move away from the Gnome Partition Editor: https://gparted.org/
You can grow and shrink volumes from within Windows Disk Manager, the only time you need a tool like this is to move a partition out of the way so you can grow another one.
Yes it's annoying that Windows Disk Management doesn't let you remove a system partition even when it isn't currently in use.
You say Windows as if any other OS can do it... they cannot. Linux won't let you play like that on a disk with any partitions mounted. I don't think MacOS can do it either. I'm not personally clear on why, but if everyone is playing by the same limitations I have to assume there's a solid reason.
Yeah I generally only need it when I restore a system image to a newer bigger drive which is literally a couple times a year at most.
That's not what I'm referring to. I mean a hidden system partition that's used for booting but the drive is now connected to a PC running from a different boot drive. I meant the partition is not in use for the booting the currently running OS, it's on a slave drive. Minitools Partition Wizard can delete the partition because it's nothing to do with the RUNNING system. Disk Management artificially prevents its deletion, probably to prevent issues in a dual-boot configuration.
Oh... yes..
But diskpart I think can handle this, but you're right the GUI wont.
This is a good discussion - I've got an application server VM that is running low on space for the C: drive. 200GB seemed fine when it was new, but after several new softwares were loaded over a few years, it's just not. Can't grow the partition in disk manager for the reasons already discussed.
This is a perfect use case for gparted.
Power down the VM, and make a snapshot/checkpoint. Make sure your backups of the VM are solid for good measure.
Edit the virtual disk to be larger.
Boot the VM to a GParted ISO.
Move the partition that's in the way to the end of the new volume.
Save and exit.
Reboot to Windows.
Grow C.
I always grow filesystems from within the OS in question, it's safer!
