HCHTech
- Pittsburgh, PA - USA
When we have a maintenance window scheduled to install updates for LOB apps, there is a typical requirement that no one be using that app. We send out a couple of reminder emails about getting out, but inevitably, someone (or a group of users) don't listen and leave that app open on their workstation, thwarting the update.
Right now because most of my clients are small, I typically remote into the offending workstations and close the app manually. I can't just close the open files from the server's computer management window as they will just open back up again. This process always adds time to the maintenance window.
I've considered scripting a task kill command to all workstations with our RMM - I could also force a reboot on the offending workstations, but that would likely result in lost data or corrupted files. I don't care about lost data - they were warned - but if it corrupts the apps database, then that's a bigger problem I'd like to avoid.
Is there an obvious solution I'm missing to make this inevitable job easier? Surely networks with 500 workstations have this same problem and don't do the one-at-a-time fix...
