YeOldeStonecat
- Englewood Florida
Wanting to get a script going in Syncro for uninstalling Flash. There was a recent thread in the FB Syncro users group where someone asked and some peeps posted what they found, but nobody actually tried. I tried both that were posted and neither worked for me. No matter if it was Flash NPAPI or Flash ActiveX.
Script one that I tried...with no luck...
$client = new-object System.Net.WebClient
$client.DownloadFile(“https://fpdownload.macromedia.com/.../uninstall_flash...”,“c:\windows\temp\uninstall_flash_player.exe”)
start-process -filepath "C:\windows\temp\uninstall_flash_player.exe" -ArgumentList "-uninstall"
Script two....is supposed to leverage Microsofts Flash uninstaller...KB4577586
Created on: 0/01/2021 13:06
Created by: Ben Whitmore
Organization: -
Filename: Install_Flash_Removal_KB4577586.ps1
Target System: Windows 10 Only
Version:
1.2
Fixed 20H2 coding error - Credit @AndyUpperton
1.1
Basic Transcript Logging added
1.0
Release
#Set Current Directory
$ScriptPath = $MyInvocation.MyCommand.Path
$CurrentDir = Split-Path $ScriptPath
$Log = Join-Path $ENV:WINDIR "Temp\Flash_Uninstall.log"
Start-Transcript $Log
#Set WUSA.EXE Variable
$WUSA = "$env:systemroot\System32\wusa.exe"
#Get OS Release ID
$OS_ReleaseID = Get-ItemProperty "HKLM:SOFTWARE\Microsoft\Windows NT\CurrentVersion" | Select-Object -ExpandProperty ReleaseID
#Rename variable for Windows 10 20H2 ReleaseID because the same update is used for 2004/2009
If ($OS_ReleaseID -eq "2009"){
$OS_ReleaseID = "2004"
$OS_ProductName = Get-ItemProperty "HKLM:SOFTWARE\Microsoft\Windows NT\CurrentVersion" | Select-Object -ExpandProperty ProductName
#Get OS Architecture
$OS_Architecture = Switch (Get-CIMInstance -Namespace "ROOT\CIMV2" -Class "Win32_Processor" | Select-Object -Unique -ExpandProperty Architecture) {
9 { 'x64-based' }
0 { 'x86-based' }
5 { 'ARM64-based' }
#Build OS Version String
$OS_String = ($OS_ProductName -split "\s+" | Select-Object -First 2) -Join ' '
#Build Patch Name String
$PatchRequired = "Update for Removal of Adobe Flash Player for " + $OS_String + " Version " + $OS_ReleaseID + " for " + $OS_Architecture + " systems (KB4577586)"
#Get Patch Titles
$PatchNames = Get-ChildItem $CurrentDir | Where-Object { $_.PSIsContainer } | Foreach-Object { $_.Name }
#Check if the patch has been downloaded for the current system
$PatchFound = $False
#Check Installation
$Patch = Get-Hotfix | Where-Object { $_.HotFixID -match "KB4577586" }
If ($Patch) {
Write-Host "Patch Already Installed"
else {
Foreach ($Patch in $PatchNames) {
If ($Patch -eq $PatchRequired) {
$PatchFound = $True
#Get MSU from the correct Directory
$MSU = Get-ChildItem (Join-Path $CurrentDir $Patch) -Recurse | Where-Object { $_.Extension -eq ".msu" }
$MSUFullPath = Join-Path (Join-Path $CurrentDir $PatchRequired) $MSU.Name
#Set WUSA Args
$Args = @(
"""$MSUFullPath"""
"/quiet"
"/norestart"
#Patch detection determines outcome
If ($PatchFound) {
Write-Host "Patch found for this system"
Write-Host "Patch Required: $($PatchRequired)"
Write-Host "Patch Name: $($MSU.Name)"
Write-Host "`Installing Update..."
#Install Patch
Start-Process -FilePath $WUSA -ArgumentList $Args -Wait
#Check Installation
If ($Patch) {
Write-Host "Patch Installed Successfully"
else {
Write-Host "Patch Installation Failed"
else {
Write-Host "Patch not found for this system"
Write-Host "Current System: $($OS_String) $($OS_ReleaseID) $($OS_Architecture) PC"
Stop-Transcript
Organization: -
Version:
1.2
1.1
1.0
Release
#Get OS Release ID
9 { 'x64-based' }
0 { 'x86-based' }
5 { 'ARM64-based' }
#Get Patch Titles
#Check Installation
If ($Patch) {
else {
$PatchFound = $True
#Set WUSA Args
$Args = @(
"""$MSUFullPath"""
"/quiet"
"/norestart"
If ($PatchFound) {
#Install Patch
#Check Installation
If ($Patch) {
else {
else {
Stop-Transcript
