Blue Banana
- South Africa
Sorry that I have to create a whole new thread for this but I need a quick answer. A client moved his office and one of the original network cables I installed is now too short to get across to one PC. He needs all network cable stuff to be done by tomorrow. So I've thought and decided I could cut off the short cable and extend it.
The cables in his office are 568B. I only have older 568A cables lying around which I can use as an extension. Can I do this? Won't there be some sort of a connectivity issue if I mix the cable types? I'll want to make a cut in the 568B cable and attach the 568A cable in between the two 586B pieces, or cut off one end of the 568B cable, attach the 568A cable and re-crimp it so it is compatible with 586B. And no, there are no other means of extending the cable. I can't buy couplers or switches or a longer cable.
