Choppie
- Boca Raton, FL USA
Installing ESET Nod32 Antivirus 6 Damaged registry keys for the keyboard, nothing I can do will repair it...HELP please.
Nothing I could find on the net would help me find the fix or what keys to try to repair.
We've installed NOD32 V6 on tons of computers and never had an issue.
Could it perhaps be happening because you were doing the install from a remote session?
I believe this is similar to the upperfilters/lowerfilters issue with CD drives. Look in HKEY/LM/SYS/CCS/CONTROL/CLASS/{4D36E96B-E325-11CE-BFC1-08002BE10318} and see if there is anything in the upperfilters key. The only thing I have is 'kbdclass'. I've seen this before, some AV tools put a keyboard filter in there or they had a keylogger already? Xfinity 'constant guard' does this. Remember, you can still use the on-screen keyboard with the mouse to type stuff in.
Had 3-4 computers in the last month that had keyboard and mouse stop working after the customers installed Kaspersky Internet Security 2013. Posted some help before in this thread:
http://www.technibble.com/forums/showthread.php?t=44921
Had to offline-edit the registry.
I just fixed the problem on both computers with 100% credit going to phaZed, thanks!
This forum is awesome......
Thanks...
...C
Edit/Delete Message
Ok... I think maybe that GeeksInKhakis dude should get some credit... at least 5%.
Glad to hear you got it working.
I was working remotely on two computers in the same home office. The full version of Avast was 15 days from expiring and I was ready to try something new. So I removed avast, also used the Avast uninstaller and did the reboot. I then downloaded the ESET Nod32 installer for the trial version of Nod32 Antivirus 6 with intentions of buying the two year license for two computers for around 80 dollars. I used all the default settings during the install. Then around 50 percent through the install, a bubble message popped up near the notification area warning that a hardware device is no longer functioning or damaged, and it went off too fast for me to read the rest. While trying to activate the trial license by putting in the email address, the user wasn't able to type anything, the keyboard was DEAD! So I completed the email address in the form and activated the trial license via TeamViewer. I then went to device manager and found the keyboard was showing up but not able to install the driver. I uninstalled it, and did a refresh, and nothing worked. I went through the hardware trouble shooter and at some point got this error message:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Had the client pull the keyboard and reboot, then shut down and plug in the keyboard and boot.....NOTHING.
The computer:
Dell Precision Workstation 380
Windows 7 Home Premium 32
Standard Dell USB Keyboard
NOTE:
His sister was down the hall with the exact computer, running Avast; my goal was to remove Avast from both computers and TRY SOMETHING NEW to see how it works out. So not thinking it was something related to ESET, I logged into her box and proceeded to preform the same operation---SAME THING HAPPENED. She is an editor who works on books and does ghost writing....her computer is not DOWN as I sit here and type this.
While this distress SOS help message is posted here, I will continue to search for help on the net...its 2100 EST and I need to get these computers up and running. The clients are about 20 min away if I need to go there...
Standing by on all channels for help.....hahah...
Choppie.
