brandonkick
For whatever reason my younger brother decided to offer to work on one of these. He knows a little bit about a few things here and there... mostly what he's picked up from me and from me fixing his personal machine.
Anyways he comes back with a power supply for this machine, stating that one of his friends had said computer and it needed a new power supply. He came to this conclusion because they have three of these identical machines and swapped a power supply out of another one into the non working machine.
He said it "fired up" but didn't hook it to a monitor to verify anything. I'm not sure why.
So I order a power supply for this machine. Not an exact replacement mind you, because the customers don't have a lot of money and they were willing to gamble on a $30 PSU that "might fit and work" vs the proper one which is selling for quite a lot more on ebay. IIRC even that wasn't an exact match but much closer.
Anyways i get the new one and install it, re seat the cpu and apply new compound (because my brother removed the HSF in taking out the old power supply).
I fire it up and nothing on the screen, nothing on the green LED on the front of the machine. I compare the 24 pin connections on the power supplies (old and new) to verify everythings as it should be. No cables are swapped or missing, with the addition of a white wire in pin position #20 which in a 24 pin atx connector is N/C or in other words no connection. In pin 18 of a 20 pin connector this white wire is -5 volts.
It's the only thing I can think of? I reseated the ram, even removed it and got no memory beeps. I'm thinking of cutting that white wire and seeing if it makes a difference. I can't think of anything else?
