Pacific Blue IT
- Bongaree QLD
Whats the best solution for a single Domain server and software that requires SQL?
Im putting in the following RAID config
2 in RAID 0 for OS & programs and 4 drives RAID 10 for storage
Should I change the RAID 0 from SAS to Enterprise SSD's would this negate the SQL from being a resource hog?
The SQL software to be used is BarTender software by Seagull Scientific will it have a big impact on this system?
What is recommended hardware wise if I built a server or Workstation just for the BarTender software?
The setup Im offering the client has the following specs:
CPU
2/2Intel® Xeon® E5-2603 v3 1.6GHz Hexa Core or 2/2 E5-2650 2650 v3 2.3GHz (Supports 2133 RAM )
Motherboard
1. Dual socket R3 (LGA 2011) supports
Intel® Xeon® processor E5-2600 v3
family; QPI up to 9.6GT/s
2. Intel® C612 chipset
3. Up to 1TB ECC DDR4 2133MHz;
16x DIMM slots
4. 1x PCI-E 3.0 x16, 6x PCI-E 3.0 x8 slots
5. Intel® i350 Dual port GbE LAN
6. 10x SATA3 (6Gbps) ports w/ Intel
C612 controller; RAID 0, 1, 5, 10
7. 8x SAS3 (12Gbps) ports w/ LSI 3108
controller (2GB cache); RAID 0, 1, 5,
6, 10, 50, 60
8. Integrated IPMI 2.0 and KVM with
Dedicated LAN
9. 5x USB 3.0 and 4x USB 2.0 ports
Memory
16GB RECC 2133MHz (2 x 8GB)
Memory Capacity
24 x 240-pin DDR4 DIMM sockets
Supports up to 1.5TB DDR4 2166MHz ECC LRDIMM
Memory Voltage
1.2 V
Chipset
Intel® C612
HDD
6 x 300GB SAS 15K RPM Hotswap (8 HDD Max) 2 in RAID 0 for OS & programs and 4 drives RAID 10 for storage
Drive bays
8 x 3.5" Hotswap SAS/SATA Drive Bays + 2x 5.25 + 1x 5.25" bay that fits 3.5" bay devices
HDD Controller
SATA3 (6Gbps) and SATA2 (3Gbps)s Controller
SATA / SAS ports
SATA 3.0 6/Gbps with RAID 0, 1, 5, 10 & SATA 2.0 3/GBps with RAID 0, 1, 5, 10
SAS3 12GB/s HW RAID 0, 1, 5, 6, 10, 50, 60 support via LSI 3108
2GB Cache via SuperCap backup module
Network Controllers
Dual Intel® i350 GbE Controller
LAN
2x RJ45 Gigabit Ethernet LAN ports + 1 x Dedicated IPMI LAN Port
Graphics
Aspeed AST2400 BMC graphics controller
USB
4x USB 2.0 ports (2 rear + 2 via header)
Expansion capability
1x PCI-E 3.0 x16
6x PCI-E 3.0 x8
Video
1x VGA
Serial Port/Header
2 Fast UART 16550 ports: 1 rear and 1 header
DOM
2x DOM (Disk on Module) ports
Other
1 TPM 1.2 20-pin Header
Server Management
Intel® Node Manager 3.0
IPMI 2.0
SPM
SUM
SuperDoctor® 5
Watch Dog
NMI
Chassis Form Factor
Pedestal
Power Supply
1+1 920W Redundant High-effciency 80+ Platinum Power Supply with PMBus and I2C
CPU
Motherboard
16x DIMM slots
6, 10, 50, 60
Dedicated LAN
Memory
Memory Capacity
Memory Voltage
1.2 V
Chipset
Intel® C612
HDD
Drive bays
HDD Controller
SATA / SAS ports
Network Controllers
LAN
Graphics
USB
1x PCI-E 3.0 x16
6x PCI-E 3.0 x8
Video
1x VGA
Serial Port/Header
DOM
Other
Server Management
IPMI 2.0
SPM
SUM
SuperDoctor® 5
Watch Dog
NMI
Chassis Form Factor
Pedestal
Power Supply
