HCHTech
- Pittsburgh, PA - USA
I ran into something new (for me) today. Went to a customer's house to install a WAP in their barn. The electrician had already run ethernet out to the barn, so I figured it would be a simple job. Um, no. Turns out they had used a very thick direct-bury Cat6. Looked like standard Cat6 inside with the plastic cross separating the pairs, but there was some kind of extra insulation over the cable, it was then metal spiral wrapped, then plastic/rubber coated on the outside. This stuff was very stiff and probably 10 or 12mm in diameter. Really difficult to work with.
As (my) luck would have it, the cable was wired incorrectly - just straight pairs left to right. She's a no work.
All I have is tools to work with regular indoor wiring, but I give it a whirl anyway. I pull off the plug, chew away at the cable with side cutters to expose a couple of inches of wires and go from there. Turns out the insulation on the individual wires is thicker than normal, and a regular RJ45 plug won't work. I tell the customer he'll have to have the electrician come back and re-terminate the cables with plugs meant for this cable, and this time wire them correctly.
"The electrician is on a big job and won't be back for two weeks - can you do something to make it work in the meantime?"
Ugh. Well, I search through my bag and ultimately find 4 different manufacturer's plugs. I try them each in turn, looking for the one with enough slop in their manufacturing tolerances to let me jam them on this monster cable. I find one that looks like it might work. It takes me about 20 minutes to get one end on. I repeat this nonsense for the other end of the cable and we get a connection. Oh, and it was 90 degrees out today. I was reminded why I don't run wires for a living, that's for sure.
