Possibly. Try removing power cable and battery, hold down power button for 60 seconds, then put power cable back in and switch on.
I just (seconds ago) got off the phone with a client whose Toshiba was also dead. Told him to remove battery, unplug, hold power button for 60 seconds, plug back in, hit power button and away it went. chuckles.......
Nope. Bios wont help if you can not post.Unfortunately I had tried that. Wondering if a BIOS update would help and if it were possible to do it blindly.
So you think the only option is replacing the mobo?Nope. Bios wont help if you can not post.
Could have hit the board with static putting ram in.
It looks that way. You may have fried it with static, or it may have just been a flaky low-quality machine about to die anyway. The only two of that exact model on Ebay at the moment are non-working parts machines; if you cast the net a bit wider and search for all L755's, you get around 40% parts machines. That tells me they're not exactly high quality. And the whole machine can be replaced for around $100, so may not be worth fixing.So you think the only option is replacing the mobo?
Exactly.so may not be worth fixing.
Get ready to replace it if your customer does not believe you did anything wrong. Some will understand and some won't and will blackball you with at least bad reviews if you don't make it right ith them..Now, how to tell the customer this? Ugh
Just double checked - both are 1.5 (whew)I'd be checking the memory that was there, vs what was installed. Because if there's a voltage difference, then yeah... you bricked it.
Given the amount of time and effort that would be required to fix this, if the client is demanding a replacement then it's likely going to be far less expensive, overall, to get a machine that matches the specs of this one as closely as possible.
If it came to getting another machine, I'd see if the client would do it (as this machine is ancient and could have gone at any time) and offer to do all the data transfer and program reinstallation (for those for which they have licenses and, possibly, media) for them at no charge.
