HCHTech
- Pittsburgh, PA - USA
Misleading headline - Lenovo wins hands down.
I have a client that insists for no defendable reason that all of their setups be identical. They are currently using Dell Optiplex 70x0 micros, with dual 27" Dell Ultrasharps, and I just installed one yesterday. Nice setup, but when you compare it to the same solution using Lenovo's Tiny-in-One stuff, it is SO MUCH more cumbersome & messy.
Lenovo has the Specific Tiny-in-one monitor made for this purpose, which has a physical connection to the little computer that slides into the mounting slot. This lets the power button for that monitor function as the power button for the computer, which saves a connection. This monitor also comes with built-in speakers and webcam, which saves an additional 2 connections. It also automatically lights up the USB ports on the monitor itself, saving 1 connection. The computer itself has 6 total USB-A connections, 4 on the back and 2 on the front, plus a USB-C connection on the front - 7 total connections for peripherals. In this setup, we're using wired keyboard & mouse, so we used a total of 4 connections (Keyboard, mouse, printer & one to light up the USB ports on the 2nd monitor. This leaves 3 unused USB ports on the computer itself and the USB ports built into the monitors as well (3 each). 9 available USB ports for future expansion. The computer also has built-in wifi - not typically needed, but a plus.
The Dell setup for this makes you buy regular monitors, and a separate replacement stand for one of them that has mounting hardware for the computer. The latest version doesn't have a slot the computer slides into, but instead four keyhole slots that the computer hangs by, once you screw in the specialty screws onto the side of the computer. It's not a tight fit, so it wobbles and just feels cheaply done and not secure.
Because the monitors don't have built-in webcams or speakers, you have to buy those separately and connect them with individual USB cables to the computer. The computer itself has 4 USB-A connections on the back and 2 on the front. No USB-C. 6 total connections for peripherals. In our setup, we used 2 for keyboard and mouse, one to light up the USB ports on the 1st monitor and one to light up the ports on the 2nd monitor, 1 for the printer, 1 for the webcam and 1 for the speaker bar. That's a total of 7 connections - the speaker goes into one of the monitor USB ports, so that means all 6 of the computer ports are taken. The monitors have 3 USB-A ports and a USB-C port. That's 6 total USB-A (minus 1 for the speakerbar) = 5 available, plus 2 USB-C available. 7 total USB ports available for future expansion.
Lastly, I couldn't get daisy-chaining working for the 2nd monitor using Displayport, so had to fall back to HDMI since the computer only had one DP connection. The HDMI connection for this computer is limited to 1920x1080, so I have one monitor at 2560x1440 and one at 1920x1080. Not fatal, just a disappointment. Finally, no built-in wifi on the Dell units.
So in the end, it's working, but way too many cables for my taste and it just feels cheaper, despite being more expensive than the Lenovo option. I'll definitely be sticking with the Lenovo solution for my recommended setups.
