Road Runner
- Tallassee Alabama
Guys I think this machine is gonna be one of the EXPENSIVE lessons learned.....
I have a friend whose daughters Inspiron 1521 had developed some kind of charging problem......I was TOLD by the father that the original dell power supply had seemed to stop working......he said the daughters friend had a power supply.....of unknown origin that would charge the machine but after time it stopped.....the mother supposedly bought a genuine dell power supply and it didnt charge the battery either.......mom and dad are divorced.....
Dad (my friend) brought it by with a new looking dell power supply and a universal aftermarket power supply.....
I checked the dell supply with my volt meter and got 19.5 volts......the jack inside the 1521 looked worn.....obviously had been subjected to a lot of different plugs going in and out......
I ASSUMED the jack inside the 1521 was bad........tore the machine down and got the jack out......
It had 5 pins soldered to the motherboard......once out I got my ohm meter and determined that 2 of the pins were "the same" zero ohms.......
2 other pins were the same......
the final fifth pin had nothing in common with the others.....
I plug the dell supply into the jack and check voltage.....19.5 volts as I expected with nothing on the fifth pin......
I try the aftermarket supply and get 19.5 as expected and also +19.5 on the mystery fifth pin........
I look at the factory dell supply and the aftermarket one closer and see the aftermarket supply has a small needle like center pin that seems to supply the +19volts to the laptop internal jack and the genuine dell supply either didnt have the needle like pin....or it might have been broken off.........
I am beginning to think that maybe I got a mixed up story from my "client" and maybe there is nothing wrong with the laptop jack.........
anyone here ever replaced the dc jack on a inspiron 1521 or similar dell that might have some insight ????
I have already ordered a new jack........
thanks
Rhett Duke
Road Runner Repair...............
thanks
Rhett Duke
