Krynn72
- Connecticut
Now, before I go any further I should say that I plan on telling him to go to a specialist since I've never done data recovery on a failing, encrypted drive before, but I'm wondering how you guys do this?
So the other day my sister's boyfriend came in with a hard drive he said belonged to a local university's graphics department. It was an external drive (just the internal hdd was brought, no enclosure, I think my sister did a quick test to see if it was just the enclosure and then told him to come here). I think it was from a WD MyBook drive though he wasn't sure. It was a WD Green (eugh) 1TB and he said there was about 150 gigs of important data they needed off the drive.
So I checked it in, plugged it into a test machine to see the state of it, and the smart status lists lots of offline UNCs (300ish) and miniXP showed the drive as unpartitioned. I cloned the drive immediately, right before closing and the cloner (Disk Jockey Pro) said it had to skip ~230 sectors. The next day he comes back in to drop off another external drive for the data to be put onto, and then mentions that there was a password to open the drive, which he didn't mention before, and which explains the "unpartitioned" space I saw. He also says its used exclusively on macs.
He couldn't remember the name of the software, but when I brought up WD Drive Lock he said the interface looked the same but that theirs looked like an older version. However the Drive lock software doesn't recognize a compatible HDD when either the clone, or the original drive are connected.
So I have two main questions I guess. The first is, would I even be able to attempt recovery from a cloned drive, or would the encryption software see that its no longer the same drive/control board and not let me do anything? And either way, how would I go about decrypting a drive that's bad enough that the software seems to not even see the drive anymore (or am I just possibly using the wrong software)?
