ClickRight
- BC, Canada
Customer has issues after work done - I don't want to fix it! (With a reason)
OK, so I did a job for a customer where her computer was trying to reinstall MS Photo Gallery on every startup. This happened after the customer ran some "clean up" program she found on her computer, not even the standard MS Disk Cleanup.
On-site, it was discovered that her hard drive was failing, and her computer was UNBEARABLY slow. I noted that she needed a new hard drive and made a backup of her documents & pics. She did not want a new drive (no $) I then proceeded with the repair.
I even took her files back to my office and burnt her a backup copy on a DVD and delivered it to her home.
Today, I get an email:
Now, I don't want anything to do with this computer. There is too great a chance for the hard drive to fail, and honestly, the computer is just too slow to even touch for my liking. Also, this is not the original issue, and technically, should not be covered under warranty (though I would usually cover it on a normal computer)
I'm thinking with responding with something along the lines of:
I don't think this is stepping over the lines, do you agree?
I don't know what you did but I can't get my pictures on my computer. It transfers from the camera okay but it tells me I have to open some kind of file or something so can you come and fix it please. Maybe its because you took out photo gallery?
If you do recall, I had to remove Photo Gallery to resolve the errors at startup. I honestly don't think I can help you with your computer issues any further, as your computer is in a critical state and needs a new hard drive (why do you think I was adamant about burning your files to a DVD?) The way I work, it's either fixed properly or not fixed at all. Unfortunately, I do not believe that I can fix the issue properly without fixing the underlying problem.
