Connecting 2 wireless routers?
After setting it up myself the only thing I recommend is a WRT54G with DDWRT on it. Took m3 less then 5 minutes to flash and I have ANY setting I coul imagine. I would set one up and just bridge your connection. Then you can setup all the static IP's you want. DDWRT also does work on some netgears so you may not even need new hardware.
On the other hand I have never used ICS and if Pro Tech says it's good, well it's good.
It is just a solution that require no extra hardware. Assuming someone else was looking at this thread and was in a simliar situation - they could resolve it without any extra hardware, just a wireless router and a computer (and optionally a switch).
