computer has rebooted from a bugcheck windows 7
johnrobert
Vancouver BC
Hi
The 0x00000022 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
The best advice would be to restore the computer to an earlier time if the computer does still boot.
I hope this helps or at least points you in the right direction.
I copied the mindump folder C:\windows\minidump
How can I view the mini dump file to find the problem
Looks not so easy.
I get about 40 minidumps of MEMORY_MANAGEMENT all with same address
I would guess you are right about it being bad MEMORY
Bug check string MEMORY_MANAGEMENT
Bug check code 0x0000001a
Caused by driver ntoskrnl.exe
Caused by address ntoskrnl.exe+705c0
File description NT Kernel & System
Crash address ntoskrnl.exe+705c0
Probably is the RAM, but best to test it either way. Windows 7 has a built in memory tester in the boot menu. I tend to use memtest myself.
