Marius
- South Africa
Comfix (Combofix Add-on)
Here is a small utility i compiled that resides next to Combofix. If your Combofix is outdated, it might ask you if you want to carry on with LIMITED functions (usually when not connected to the Net). Also, if you're NOT connected to the net, it cant install the Repair Console of Windows.
Put this utility in the same directory as Combofix. With this utility you can:
1) Go on-line and get the latest Update from the net from 2 diff locations. (Remember to put the downloaded "new" Combofix in the same Dir as Comfix).
2) Install the Repair Console directly from the customer's Windows Cd WITHOUT the need of being on-line.
3) Run Combofix after you have finished with the above...
http://www.mariuscomputers.co.za/comfix.zip
