allanc
- Toronto, Ontario, Canada
First, let me say that I know very little about CNAME, SSL Certificates, etc.
I am trialing ZenDesk for my ticketing/help desk.
They suggested that I use a CNAME record to 'redirect' support.mywebsite.com to mywebsite.zendesk.com.
My Web Hosting company created the record and it seems to work.
Reading the ZenDesk site they are suggesting:
"However, because our SSL certificate is not valid for your new address, you must provide us with a SSL certificate. If not, your users may experience certificate errors or be redirected to your default zendesk.com subdomain." from this page.
Is this something that I should / must do?
The only specific specifications that I can find are:
"Before you buy, make sure your certificate authority supports SHA-2 encryption. The CSR file generated in Zendesk uses SHA-2 encryption.If prompted, specify "Nginx", "Apache" or "Apache + mod_ssl" as the desired web server"
If I was to use NameCheap which of the certificates from this page do I need?
By the way - the certificate gets installed at ZenDesk.
Thank you in advance for all assistance.
