boot normal/ safe mode/ rootkit
supertech365
Mississippi
Strange problem with xp system. Viruses were suspected on a pc. Ran a few process viewing programs, malware checks, etc. in safe mode. restart pc and desktop is classic xp version. services are stopped, can't start them up manually. It gives error: 'can't start in safe mode'. dial-a-fix renoved disabled policies but still no cigar. also there is even an account named 'administrator' in the user logon like its in safe mode. is this a rootkit. i cant even edit boot.ini. Is there a fix?
This key gets set in safe mode, it should not be there when windows is running normally. A Dword value of 00000001 will be set in Safe Mode Minimal, Dword 00000002 will be set in Safe Mode Network
Code:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\
Not sure why it sometimes hangs around when windows is started normally but i've seen it on virus free computers as well.
A little note you can add the key
Code:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Option]
"OptionValue"=dword:00000001
to enable security tab in xp home, just remove it before restarting.
WOW! It has started again in safe mode. No services have loaded and desktop theme looks like xp classic. I will search for the registry keys manually that were mentioned by waredat and let you know if i have luck.
That maybe a variant of the rootkit i am seeing now i usually use unhackme it's a bootime rootkit/worm/trojan detector does a really good job.
most rootkit software just finds rootkit this one finds and removes it never had it fail yet.
