I'm posting this after the fact so I can learn; Friday I got calls from two different clients with computer problems.
The first PC booted past the splash screen, right to a blinking cursor with black scree. Ended up pulling the drive & connecting via USB to my laptop, only to discover it was in RAW format & prompted me to format the disk.
I was able to use PartedMagic to recover all documents, PST, etc. and my antivirus tripped a couple times while transferring the files, so obviously there were some threats in there. Could the viruses alone have done that to the disk?
Another client, same thing, except I think it was truly a failing drive and I was NOT able to recover any files, fortunately she's got a good, recent backup.
Anyway, I was poking around online & virtually all the stuff I found pertained to external USB drives becoming formatted as RAW - what would cause this to happen to your primary disk?
The causes I found are;
- Virus
- Failing hardware
- Sudden power failure
Anything else? Can you fix/repair a drive like this, or do you just do what I did which is to recover data (if possible) and replace it?
Thanks
- Virus
- Failing hardware
Thanks
