TCG
- Los Angeles, CA
I know there was just a thread on 3 monitors, and now I have a question about 12.
A little background
I have a client who wanted to use 8 monitors and he wanted to drive them from his laptop, bought those USB adapters and had lots of trouble, I urged him to get a proper desktop, which he did. A Dell Precision with 64GB RAM, and 2 NVIDIA Quadro video cards with 4 mini display ports each, we hooked up his 8 monitors and everything was great, till he decided he wanted 11 monitors because of good cyber Monday deals. I'm not a fan of splitting video signals, so I found him AMD Radeon 7700 series video cards with 6 mini display port each. I couldn't get it to work correctly with Mini DisplayPort to display port cables and ended up using Mini DisplayPort to HDMI active adapters, this worked and everything worked great till he decided he wanted a 12th monitor. He hooked it up himself and it work for a day or so until he decided to try to adjust the resolution, then only 3 monitors would work.
What I've done
Each monitor works individually, in each port, and with each active adapter. When I plug monitors in, they will start working until about 8 of them are plugged in, then some go off. I got to the point where I could have 9 plugged in and 7 working. When all 12 are plugged in, only 3 work and it's the same 3 every time. I've reset the video card settings to default, I've updated to the latest drivers and tried the original drivers. I noticed that when all 12 were plugged in, 9 of them were disabled through the software, so I started enabling them 1 at a time, at about the 10th one, it would reset to only 3 working. I currently have 9 working. At one point I got all 12 for about 5 minutes and then it went back to 3.
These are the current video cards http://www.amazon.com/VisionTek-Rad...F8&qid=1455066130&sr=8-5&keywords=Radeon+7750
I've attached some pictures, only 11 monitors are visible in the picture, the 12th one is a 65" TV off to the side. The picture with the 3 that are on, seems to be the default configuration when all 12 are plugged in.
