- Thermalright HR-03 VGA Videocard Cooler Review @ Tweaknews.net
- MSI P965 Platinum Mainboard Review @ Technic3D
- DVD Formats Explained @ OCModShop
- TV Calibration Tips @ eCoustics
“The HR-03 VGA cooler is a great leap forward for Thermalright, putting them back in the VGA cooling business with a vengeance. The innovative design and dual configuration mounting system combine to make the HR-03 a real winner. Good passive cooling performance and monstrous active cooling should make gamers very happy, and anyone overclocking a card with this cooler and fan combo won’t have to worry about heat holding them back.”
“The MSI P965 Platinum Mainboard arrived Technic3D. The fanless Mainboard with a small Price for Gamer with Intel 965 Chipset. Faster than other P965 Mainboards? We test this against the Gigabyte DQ6 and Foxconn P965AA. See you the result in the following Review on Technic3D”
“The name Blu-ray Disc is derived from the blue-violet laser used to read and write this type of disc. Because of this shorter wavelength (405 nm), substantially more data can be stored on a Blu-ray Disc than on the common DVD format, which uses a red, 650 nm laser. In comparison to HD DVD, which also uses a blue laser, Blu-ray Disc has more information capacity per layer (currently 25 GB, but test media is up to 33 GB). Several manufacturers have released 50 GB recordable BDs and rewritable discs. All supporting studios have either already released or have announced release of movies on 50GB discs.
In comparison to its main competitor, Blu-ray Disc, HD DVD has less information capacity per layer (15 gigabytes instead of Blu-ray Disc’s 25). HD DVD shares the same basic disc structure as a standard DVD: back-to-back bonding of two 0.6 mm thick, 120 mm diameter substrates.”
“To get the maximum performance out of your brand new HDTV set or an older CRT (picture-tube) set, here is a list of typical TV picture ills, and a basic guide to fixing them.”
Articles
Blogs
Kits
Forums
Bryce Whitty
