- Zalman FATAL1TY FC-ZV9 Videocard GPU Cooler Review @ Tweaknews.net
- Gigabyte GA-M61PM-S2: A Full-Featured Plug-and-Go Motherboard for AM2 @ OCModShop
- Gigabyte 3D Rocket II CPU Heatsink Review @ Technic3D
- Fragapalooza 2006 @ The TechZone
- VIZO Ninja Laptop Cooler Review @ Futurelooks
- Kinc warming up with 3DMark 03 world record: 84.244 points! @ NordicHardware
- AMD Athlon 64 X2 5200+: Desktop Multi-Core Gets Close To Athlon 64 FX Review @ Digit-Life
“When Zalman and Fatal1ty team up, you expect some special results. The FC-ZV9 graphics card cooler combines good cooling performance, great looks and wide compatibility into a product that any gamer would be proud to have in their case. The nickel plating and red LEDs give it a distinctive look that many folks will find appealing. The price, however, may deter some potential buyers.”
“Gigabyte’s GA-M61PM-S2 is geared towards the user who just wants everything to work right away and get the job done without breaking the bank.but at the same time, getting the job done comfortably, because as you will see there are some things that make this board special. It is the Honda Accord of motherboards if you will – not pretentious or glamorous, but just a cut above the Honda Civic. The board is based around Nvidia’s GeForce 6100/nForce 430 chipset, and has on-board everything: Nvidia graphics, 8 channel High Definition Azalia audio with a header for optional S/PDIF output, gigabit ethernet, 4 USB ports with 3 internal headers for a maximum of 10 USB ports, 1 firewire port (IEEE 1394) with 2 internal firewire headers, 1 IDE/ATA 133 connector (kind of a bummer since a lot of people still use many parallel ata devices), 4 SATA II ports, and RAID (0,1,0+1,5).”
“The Gigabyte 3D Rocket II CPU Heatsink arrived Technic3D. The Rocket Cooling? See you in the following Review against others CPU Cooling.”
Fragapalooza 2006 (Part 1, Part 2, Part 3) @ The TechZone
“Fragapalooza is Canada’s largest LAN event, and this year they celebrated their 10th year in a BIG way. I braved many a sleepless night to bring you all the details and goings-on at Fragapalooza X.”
“Ouch! Hot laptop! As most laptop owners know, systems can get pretty hot to the touch. So hot, that you never want them anywhere near your lap. The VIZO Ninja laptop cooler can help things cool down a bit while being silent like a Ninja. Built of solid aluminum, the Ninja is also durable, but will it be the right cooler for you?”
“Kinc has spent the day warming up before DreamHack by testing his system with dual graphics cards, I.e. SLI. Earlier it’s been single-card records, but this time it’s all the way with dual cards. He has primarily focused on 3DMark 03 and then managed to reach 84,244 points, a new world”
“Whether you like it or not, AMD continues to expand its range of desktop dual-core processors for Socket AM2 combining just two parameters: core clock rate and L2 cache size. This article is devoted to another combination of the well-known components: L2 cache of Athlon 64 X2 4800+ (1 MB per core) and clock rate of Athlon 64 X2 5000+ (2.6 GHz). Thus, having gained the key advantages of both previous models, the processor got the name of Athlon 64 X2 5200+.”
Articles
Blogs
Kits
Forums
Bryce Whitty
