Thanks
@sapphirescales, interesting sort of undocumented feature. So I decided to check it out. Flashing the PRAM does remove that entry but when the machine boots to the existing OS it reloads those values. But when I check in iCloud FMM is turned off FMM when it was on before. Explains why my MBP Retina is no longer discovered in FMM. The big question is what happens with a new drive and if the machine is a pre firmware restore or a post firmware restore. If Apple hasn't fixed this issue with the newer firmware machines, doubt it will be done with the older ones, we may a solution for this pesky problem.
