HCHTech
- Pittsburgh, PA - USA
This is a late-2011 machine, hard drive was replaced with an SSD a couple of years ago by the geniuses. When powered on, you get the normal chime, and the loading bar creeps slowly across until it his about 33%, then the screen goes white, there is a brief two-second period where it displays a 1/2" horizontal bar of scrambled pixels about a 1/3 of the way down the screen, then that disappears and it sits at a white screen.
This sounds like a logic board from this point.
I've tried to boot to recovery with Command-R, but that has no effect, you never get the recovery screen, just a white screen.
I've tried to boot to an external drive, but you get the same behavior minus the horizontal bar of scrambled pixels.
The [Toshiba] SSD tests ok in gSmartControl, 14K hrs, no errors in the smart logs. Browsable in linux.
I put what I thought was an empty hard disk in to see if I could install OSX on a fresh disk - turned out the disk wasn't empty and it booted to windows 10 - haha. I noticed the desktop background wasn't smooth, it was made up of broken lines of the correct color. Here is a zoom of that:
This lasted about 2 minutes and Windows 10 bluescreened - no surprise.
So I started over again, and booted to a USB installer to try and install on a fresh disk, but after choosing the USB as the boot device, the loading bar stopped again at about 33% and the machine went to a white screen.
I don't have a spare hard disk cable, even though I vowed to buy one the last time we found that problem on a Macbook.
Anything I missed - or are we back at a logic board failure?
