BlackLabTechs
- Maine
Why not just do a 4 pole rack. Enclosed or not. 48u.
OP says they would rather not take up floor space as the room may be used as office for some other equipment.
They keep changing their mind on every aspect of this new office building.
I'm re-thinking about getting a floor rack, 24U would be more than enough space. If I want access to the front and rear of the rack (and doors to swing out without hitting walls, 6' x 8' room dimensions roughly), I'd have to put it in front of the backboard, with rear door facing the backboard. So that would mean a transition from the backboard by at least 3 feet to the top of the floor rack to bring the cabling into the rack. Maybe I am just over-analyzing things. I want it to be as best as I can do and not think "hey I wish I had done it a different way" years later. The room can be locked (handset would need to be changed), so I guess I don't have to get a locking cabinet.What transition do you mean. Just mount patch panel towards top and cable tie into a nice bundle to each patch.
I use keystone patch panels and generally do patch, switch, patch, switch
I plan to leave a service loop if there is enough cable. I don't make an actual loop (i.e. circle) of cable. I like the U shaped service loop.How do people feel about leaving a chunk of those loops of cable coiled (neatly, and wrapped) on top of the rack as a service loop? That or terminating to patch panels up near where they come out, then using patch cables over to the actual equipment rack?
