Mick
- Cambridge, UK
I have a situation with a SBS 2008 R2 which is stumping me. This server is a DC and has seven workstation clients attached, all running Win 7 Pro - all up to date and patched. Just one of these clients is losing connectivity to certain (but not all) websites on a regular basis (i.e every two or three days). Typically, affected sites are those requiring log-ins, e.g. on-line banking services, so mostly they are HTTPS sites. The server itself also loses connectivity to these sites, so if I browse a site directly from the server, I get the same result. However, the other workstations are fine or, at least, have yet to report this as a problem.
I've cleared the situation by running a 'dnscmd /ClearCache' followed by 'dnscmd /StartScavenging' on the server and this does work....for a day or two, then we're back to square one. I've run BPA on the DNS server and all is clear. I've checked the settings on the affected client and it's getting its DNS direct from the server and nowhere else. I've used three different browsers - IE, FF and Opera. The whole rig is protected with Panda Endpoint, but I've also scanned with MBAM just in case...nothing found. I'm a bit stuck as to where to look next. The ClearCache routine does work, but it is obviously dealing with the effect rather than the cause. It's also a bit time -consuming. Any ideas/suggestions welcome.
