Old 07-06-2009, 08:32 PM
tymiller's Avatar
tymiller tymiller is offline
tymiller is an unknown quantity at this point
Default Laptop Fan High
Hey guys,
I have a client's computer that I just replaced the motherboard on. I also reformatted and put a new hard drive in. The fan is staying at high speed the whole time. Both cores stay between 38-40C when idle. It is a Toshiba satellite P305. Any ideas?
Thanks!
Old 07-06-2009, 08:38 PM
computergeek1 computergeek1 is offline
Banned
computergeek1 is an unknown quantity at this point
Originally Posted by tymiller View Post
Hey guys,
Thanks!
What was the issue\problem before you replaced the motherboard and hard drive, i am with ACG need more info.
Old 07-06-2009, 08:51 PM
tymiller's Avatar
Ok,
Toshiba Satellite P305-S8825.
Running Vista 32-bit
Intel Core2 Duo T5550 1.83 GHz
3GB Ram
What else do you need? Motherboard was replaced with same P/N as original.
Problem before was, it wasn't powering on.
Old 07-06-2009, 08:53 PM
K007's Avatar
K007 K007 is offline
K007 is an unknown quantity at this point
Ok,
3GB Ram
As I said, new m-board = new bios chip.
Upgrade the BIOS !!!
Edit: new bios chip almost invariably = old bios version
Old 07-06-2009, 09:12 PM
tymiller's Avatar
Well, I installed the chipset driver and that fixed some of it. I will try to flash the BIOS also. Just use the update from toshiba?
Old 07-06-2009, 09:17 PM
anonymous Mac Tech's Avatar
anonymous Mac Tech anonymous Mac Tech is offline
anonymous Mac Tech has a spectacular aura aboutanonymous Mac Tech has a spectacular aura about
Hey guys,
Thanks!
I'd check for sensors that might not have been reconnected to the board. Just seems to make sense. Whenever I replace a board on anything and fans are full bore, that's usually what the problem is. I'm just saying that's usually it because I've done tons of boards on desktops and laptops and its easy to leave a sensor unplugged. AS far as the temps concerned its gonna run cool with the fans on high.
Old 07-06-2009, 09:37 PM
studiot's Avatar
studiot studiot is offline
studiot is on the way
I doubt if it is the BIOS, never had that as a cause.
Could the fan be running because it needs to? ie did you put the heatsink back properly?
Is the fan new? Could the fan assembly itself be damaged in whatever happened ie was it overdriven for a long time before the fault till the sensors failed so are the sensors reporting any speed at all. thus causing the system to demand more and more drive?
Use speedfan or SIV.
If it ain't broke
Fix it until it is
Old 07-06-2009, 09:40 PM
tymiller's Avatar
Seems like problem is solved.
Thanks.
  #9
Old 07-06-2009, 09:48 PM
NYJimbo's Avatar
NYJimbo NYJimbo is offline
NYJimbo has a spectacular aura aboutNYJimbo has a spectacular aura about
Thanks.
Another day of hair-pulling and teeth-gnashing avoided by help from the crew at Technibble.com !
  #10
Old 07-06-2009, 09:49 PM
usacvlr's Avatar
usacvlr usacvlr is offline
usacvlr is on the way
If a laptop is plugged in and it's power options are set in a specific way,, varies but toshiba is quite versatile then it will run at max clock speed the entire time it's plugged in.
Hey guys,
Thanks!
You Break It. We Fix It!
http://www.usalaptoprepair.com
