Old 06-16-2009, 03:13 PM
computergeek1 computergeek1 is offline
Banned
computergeek1 is an unknown quantity at this point
Default HP sleep mode
has anybody got any advise on how to get a hp laptop out of sleep mode.
switch the computer on, no post, just a black sceen, tried a external moniter but did not help, and i know its stuck in sleep mode.
have tried the power cycle where u disconnected the mains and battery and hold down the power button for 30-60 secs, then connect the battery and switch on, did not work.
tried switching on but only having the screen a little open, did not work.
anybody got any suguesstions.
Old 06-16-2009, 03:33 PM
Banned
Originally Posted by ACG View Post
Are you sure it's a sleep mode issue? Can you run a live CD on it? Have you tried any diagnostics on the hardware?
yes i am sure, can't run any thing from the disk drive because the screen stays black, tried it with out the hard drive and memory, but got a beep to say theys no memory. so i thought the external monitor might help but still black screen, no post, keyboard does not respond, hard drive light blinks and then stops blinking. its annoying to say the least. cheers ACG
Old 06-16-2009, 04:17 PM
usacvlr's Avatar
usacvlr usacvlr is offline
usacvlr is on the way
Check the lid switch..
You Break It. We Fix It!
http://www.usalaptoprepair.com
Old 06-16-2009, 04:18 PM
Banned
Take out the HDD and leave just the memory. Then try a live cd.
still the same mate.
Old 06-16-2009, 05:02 PM
Bloogen Bloogen is offline
Bloogen is an unknown quantity at this point
Is there any bios updates available for it? Is this a vista for XP machine? Try re-installing the video drivers as well.
Old 06-16-2009, 05:06 PM
Banned
its a vista, can't put any drivers on or bios updates and i as stuck at a black screen, can't access the bios or anything
Old 06-16-2009, 05:10 PM
NYJimbo's Avatar
NYJimbo NYJimbo is offline
NYJimbo has a spectacular aura aboutNYJimbo has a spectacular aura about
Did you yank the CMOS batt and try to let it drain out. Not the normal battery, the CMOS batt.
ps- can we have a rule that when you ask for help you must post the make and model of the computer you are
dealing with. That should be the first thing someone posts when asking for help.
Old 06-16-2009, 05:17 PM
Banned
tried that as well, its a HP Pavilion dv6626us. thanks again NYJimbo will do
  #9
Old 06-16-2009, 05:24 PM
Rider Rider is offline
Rider is on the way
I have to go with Cav on this one, check the lid switch.
  #10
Old 06-16-2009, 05:29 PM
NYJimbo's Avatar
I think we need to start over.
Why do you think its in sleep mode?. Please explain that.
Also what indication do you see its in sleep mode and not having some other kind of issue.
