Well... it looks like a lot of us are now working with win7. Figured we can start posting all of the tips and tricks we find here.
hold down Ctrl+Shift while you click on the icon, and you’ll immediately launch it with full administrative rights Hold SHIFT + RIGHT-CLICK on any folder in Windows Explorer to show the advanced items in the context menu such as Open command prompt here: Click on Start -> All Programs -> Maintenance to create a repair disk Windows 7 tweaker: http://tevfikbinen.turkiye.it/Projects/SetteMaxer/ Change the Win 7 Login Background Picture: http://www.technosamrat.com/windows/...round-changer/ UAC is far better than it is on Vista, but if you still want to change the settings: Type UAC in the start menu search field and hit Enter -------------------------- If you turn UAC off, you won’t be able to run gadgets that run on your desktop. Windows regards them as a security threat, you see. However, that threat is only potential and most likely nothing bad will happen. If you are comfortable with that, here’s how to use gadgets with UAC turned off: 1. Create a Restore point or backup the Registry, because you’ll need to edit the Registry 2. Type regedit in the Search bar and press Enter to launch Registry Editor 3. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Sidebar\Settings 4. Create a new DWORD value called AllowElevatedProcess. To do that select Edit - New DWORD (32-bit) Value and name it AllowElevatedProcess 5. Set its value to 1 6. Close Registry Editor. Right-click the desktop and select Gadgets. Now you will be able to add and use gadgets as you would normally. --THANKS AUSLOGIC ---------------------------------------------------
----------------------------------- Chris Pfeffer Military: United States Army Communications and Networking Specialist Civilian: Service Desk Team Lead http://www.geekhelp4u.com |
gadgets are working in RC with uac turned off
tips, hold windows key and teb, to get peek preview. WINDOWS KEY AND X , WINDOWS MOBILITY CENTER maybe possible in vista never tried it. windows key and P, projecter windows key and # 1 will open up first icon in in taskbar #2 the 2nd and so on.. windows key and break opens system windows key and f12 try it when browsing, windows key and - ,= , magnifier Last edited by abe; 05-06-2009 at 07:05 PM. |
The "show desktop" button is now on the far right of the taskbar. If you hold your mouse over it without clicking it, it'll also show your desktop.
If you installed xp mode then discovered your hardware doesn't support it, any previous installation of virtual pc will not work, you have to remove the xp mode update,
had 2 clients who tried it on their computer's and panicked when they couldn't go back and use VPC2007 sp1 |
![]() @Abe The Win+X works in Vista to. Well done guys, keep it up. I'm going to download and install the RC later on today. |
I installed RC1 last night and I quite like some of the new features.
Its also a bit faster than Vista, though not by a huge amount, except when it comes to startup and shutdown (but then I prolly just need to reload all my usual programs lol).. |
Here are some more shotcuts for Windows 7:
Win+UP Arrow :- Maximize the current window Win+Down Arrow :- If the current window is maximized, restore it; if the current window is restored, minimize it Win+Left Arrow :- Dock the current window to the left half of the screen Win+Right Arrrow :- Dock the current window to the right half of the screen Win+Home :- Minimize all but the current window Win+P :- Open the projection menu (generally used for laptops connected to projectors) Alt+F4 :- Close the active window Alt+Tab :- Switch to previous active window Alt+Esc :- Cycle through all open windows Win+Tab :- Flip 3D Ctrl+Win+Tab :- Persistent Flip 3D Win+T :- Cycle through applications on taskbar (showing its live preview) Win+M :- Minimize all open windows Win+Shift+M :- Undo all window minimizationtop Win+D :- Toggle showing the desktop Win+Up Arrow :- Maximize the current window Win+Down Arrow :- If the current window is maximized, restore it; if the current window is restored, minimize it Win+Left Arrow :- Dock the current window to the left half of the screen Win+Right Arrow :- Dock the current window to the right half of the screen Win+Home :- Minimize all but the current window |
#9
Well it appears Win7 is no good when it comes to gaming.
After numerous kicks from CoD4 yesterday due to 'unknown API function' messages, and after trying various 'fixes' I had to uninstall and go back to Vista. Seems Pb doesnt support 7 and wont do until as long as its only available in 'Beta' format. If anyone hears Pb has fixed this problem at some stage I'd be interested to hear it. |
#10
Is anyone dual booting win7 with another OS yet? any probs - downloaded the RC this morning but wont install for a couple of days when I have time - thought I might put it in a second partition with Vista in other - thanks for all the tips by the way
| Thread Tools | |
| Display Modes | |
