Old 04-06-2009, 02:51 PM
Galdorf Galdorf is offline
Galdorf is on a distinguished road
Default Any other disk repair software out there other than spinrite and hdd regen?
I have tried spinrite v6 and i find hdd regen too slow is there anything else out there?
spinrite seems too slow real disk repair software should not hammer away at bad sectors for hours.
Hdd regen even though its great at times runs slow taking up to 3 days on large drives thats too long.
Old 04-06-2009, 04:57 PM
Marius's Avatar
Marius Marius is offline
Marius is on a distinguished road
http://www.floborecoverysoft.com/
Old 04-06-2009, 11:18 PM
lawson_jl's Avatar
lawson_jl lawson_jl is offline
lawson_jl is an unknown quantity at this point
In the Spinrite options you can set the number of times Spinrite will try and read a sector before giving up. By default it's tries 200 times I think. You could set it for 3 or so which would speed up the scanning considerabley. You may not recover as much data though.
Any answears I give are free and without warrently. I answear questions from the point of view of a working computer tech because that what I am.
Old 04-07-2009, 01:22 AM
PatrickB PatrickB is offline
Location: Springfield Missouri USA and anywhere by remote control
PatrickB is on a distinguished road
GNU DDRescue sounds like it would help if you want to recover one drive to another drive.
HDD Guru's MHDD has repair capabilities. (How did your testing go Galdorf?)
Roadkil's Unstoppable Copier may also be useful to find all the parts of the files on the failing hard drive and put them together another drive.
More related discussion in this Technibble thread: hard drive diagnostic software
-- Patrick B.
Old 04-07-2009, 01:17 PM
I was looking for something more professional around the $4000 range spinrite seem more like hype the amount of money i spent on it plus the amount of times it actually recovered drive was very low.
Hdd regen nice program works almost all the time very high success rate but very slow.
MHDD - works ok it's fast but limited success does not do everything i need it to do.
Guess ill have to look into a Ninja the clone speed is amazing and with extra upgrades ill get alot of use out of it.
http://www.yec-usa.com/products/ninja.html
Old 04-07-2009, 04:10 PM
Give you an example :
have a customers driver data is already backed up:
seagate 500 gb sata hd
1) seatools disk from seagate newest version shows no bad sectors run twice
2) HDD regen (scan only) newest version shows there is 1 bad sector in middle
3) spinrite shows no errors
4) chkdsk /r says there is 1 bad sector
now who to believe? some software says there is a bad sector other software says there is not.
Old 04-07-2009, 04:25 PM
Bobbing Bobbing is offline
Bobbing is on a distinguished road
I believe checkdisk.
Old 04-07-2009, 04:55 PM
If you are interested in the high-end data recovery software, I would highly recommend listening to a couple of podcast interviews with data recovery specialists by Steve Cherubino at Podnutz. The guests answered a lot of questions about how to setup a data recovery business.
www.podnutz.com
1) Podnutz Episode 28: Starting a Data Recovery Center
2) Hard Drives and Data Recovery w/Scott Moulton
-- Patrick B.
Last edited by PatrickB; 04-08-2009 at 01:01 AM. Reason: Removed stray graphic under my sig
  #9
Old 04-07-2009, 08:55 PM
I retested the hd under the mfg drive test program twice it shows no errors and it did not trip smart?.
I did a clone it shows an error in same spot that HDD regen scan showed scanned drive using spinrite again it shows no errors what a piece of garbage.
SO i guess i will go with what ever hdd regen scan shows i can't trust mfg testing tools or spinrite which is getting thrown in closet.
  #10
Old 04-11-2009, 06:54 PM
rusty.nells rusty.nells is offline
rusty.nells is an unknown quantity at this point
Perhaps the bad sector is flagged for non-use and some apps see it and some don't.
