Go Back   Technibble Forums > Site Stuff > Site Issues, Requests and Suggestions
Old 02-16-2009, 07:45 PM
Flyingbull's Avatar
Flyingbull Flyingbull is offline
Flyingbull is an unknown quantity at this point
Send a message via MSN to Flyingbull Send a message via Skype™ to Flyingbull
Default Just to complain
Here is a thought, either change the settings in PHP.ini to allow for a longer timeout for you mysql db, or move it to the same server as your website. I know that I've actually had to move sites because of the time drag between a database server and the website. GoDaddy.com is one of the worst, but others do it too.
Old 02-16-2009, 09:00 PM
l337's Avatar
l337 l337 is offline
l337 is an unknown quantity at this point
server seems to be getting hit pretty hard atm too gettin sad pageloads lol. im thinking the additional traffic from the toolkit and its advertisment on digg aint helpin lol
Old 02-16-2009, 10:03 PM
dhrandy's Avatar
dhrandy dhrandy is offline
dhrandy is an unknown quantity at this point
Send a message via MSN to dhrandy Send a message via Yahoo to dhrandy
Same here with failed page loads.
Old 02-17-2009, 01:19 AM
Bryce W's Avatar
Bryce W Bryce W is offline
Administrator
Bryce W will become famous soon enough
I hear you. Technibble is running a dedicated server and the MySQL database is on the same server. Right now, the server is getting slammed with traffic from being on the front page of Digg and then a heap of other sites finding Technibble on Digg, then linking to it themselves.
Digg is enough to make any server cry: http://digg.com/tech_news/A_Computer..._a_Thumb_Drive
Then of course we have Lifehacker: http://lifehacker.com/5154441/comput...rtable-package
Hang tight, it should be better soon.
Owner and Founder of Technibble - If you have a problem with any user, they are flaming/being elitist/making snide comments etc.. Press the report button which is on the top right of every post. This will highlight the post in an admin area for staff to see and deal with.
For adminly tasks such as username changes, moving threads etc.. please contact Martyn
Check out Technibbles twitter: http://www.twitter.com/technibble
Old 02-17-2009, 10:17 AM
Flyingbull's Avatar
I had a similar problem with PHP Nuke, it's one of the reasons why I don't use it any more, when our site started getting a lot of hits, it started failing connections, etc.. It is because each page needs to be compiled on demand, I have had similar problems with my older .asp/vb sites, but not as bad since I don't have a 100% database driven sites. I leave aspects of it static, and only leave the parts that needed to be generated, well that way.
Now WordPress is interesting, it doesn't seem to have the same performance issues, but I haven't seen it under stress yet, so I don't know.
Anyway, I hope your site gets better, I do enjoy posting (whining) in here,
Later!
Old 02-17-2009, 11:01 AM
Bryce W's Avatar
Administrator
Wordpress has some caching abilities which I should get working. I should also clean up the layout a bit so it requires less CPU/SQL calls. Check out what I had to do to the Computer Repair Utility Kit page so it could survive a vicious raping from Digg: http://www.technibble.com/computer-repair-utility-kit/
Old 02-17-2009, 12:09 PM
Flyingbull's Avatar
Heh, I've done that myself once or twice when I was using PHP Nuke. You know, just for the sake of keeping appearances you might try this, grab the source of the page, (View source, save to a handy folder) edit the page to have your article with the layout elements, and take the elements that refer to login or status out. Since most layout engines use nested tables, it shouldn’t be too difficult to take it out and replace it with a non breaking space
Old 02-17-2009, 01:24 PM
Flyingbull's Avatar
Originally Posted by Flyingbull View Post
Heh, I've done that myself once or twice when I was using PHP Nuke. You know, just for the sake of keeping appearances you might try this, grab the source of the page, (View source, save to a handy folder) edit the page to have your article with the layout elements, and take the elements that refer to login or status out. Since most layout engines use nested tables, it shouldn�t be too difficult to take it out and replace it with a non breaking space
Ok, just because I wasn't sure if I was being clear, I gave an example of what I meant attached (I think it attached anyway).
  #9
Old 02-17-2009, 02:23 PM
Bryce W's Avatar
Administrator
Thanks for the suggestion. I did that originally. However, servers CPU goes up to unmanagable loads whenever I do it (because of the extra image loading probably). So I had to revert it to the basic page again.
  #10
Old 02-17-2009, 06:07 PM
Flyingbull's Avatar
Your image is only like 18k the page is like 31k by itself, it would have to be something else, I would look more at the google code, I would guess that it was in there twice, having to load google add script more than once might have eaten up your bandwidth more than that image.
