Old 02-12-2009, 01:05 PM
Tiddle's Avatar
Tiddle Tiddle is offline
Tiddle is on the way
Default Quickie ...plz be gentle
When u plug up the hard drive to the power supply they usually make a spinning sound.
If they dont make that sound does it mean theyre messed up...is there anyway to get the data out?
Old 02-12-2009, 02:02 PM
Simmy's Avatar
Simmy Simmy is online now
Super Moderator
Simmy is on a distinguished road
Send a message via MSN to Simmy
If the hard drive doesn't spin up, then usually something on the PCB is fried. Without the drive spinning, then no there is no way to get the data off. You can try swapping the PCB with one taken from an identical make/model of drive or look into sending it off to a data recovery specialist.
If you're trying to connect the drive up via USB, then some drives don't power up until the USB cable is plugged in (I've seen this a few times mainly on laptop and external hard drives).
Old 02-12-2009, 02:55 PM
Tiddle's Avatar
yeah im doing it through usb
I loaded the Clients Drive and nothing no Spin
I loaded one of my olds ones it worked fine.
This computer seems pretty fucked the power supply is out
the hard drive isnt loading
and then this... http://www.technibble.com/forums/showthread.php?t=4184
lol
