Old 03-20-2013, 02:00 AM
Abet Computers's Avatar
Abet Computers Abet Computers is offline
Abet Computers is on a distinguished road
Question Computer hangs at setup is preparing your computer for first use. Win 7 x64
I am having an issue with this HP Compaq CQ56 I had to replace a crashed hard drive computer hangs at setup is preparing your computer for first use.
It will not boot past I have been waiting 2 hrs
Tried reinstalling a few times, via USB, DVD, and External DVD nothing changed all get hung up on the "setup is preparing your computer for first use"
Running Windows 7 HP x64
I have tried installing Vista, and 8 both hang during setup as well, Ran HD test, and Swapped RAM and full diagnostics ( all passed )
Someone got any ideas?
Running on 4 hrs of sleep...................... and I am dwindling fast.
Time Is Just A State Of Mind
Please Visit My Site
www.Abetcomputers.com
Aiding In Computer Repair
Old 03-20-2013, 02:12 AM
Vicenarian's Avatar
Vicenarian Vicenarian is offline
Vicenarian has a spectacular aura aboutVicenarian has a spectacular aura about
Perhaps some BIOS settings or peripheral hardware?
2 Corinthians 5:21 "For God made Christ, who never sinned, to be the offering for our sin (by dying in our place), so that we could be made right with God through Christ."
Old 03-20-2013, 02:23 AM
nope cheap BIOS - nothing editable except clock and boot sequence
Old 03-20-2013, 03:11 AM
FremontPC FremontPC is offline
FremontPC will become famous soon enough
At that point, I'd be looking at the RAM. Did it get an upgrade somewhere along the line? Check 'em and see if they match, pull the one that isn't oem first.
Is the factory restore partition intact?
Old 03-20-2013, 03:25 AM
I tried the RAM, the computer came to me with them saying it was movin g really slow and could not open up programs and it would blue screen, so ran the diag, it popped up instantly with failed HDD and they said they would like to max out the RAM ( i upgraded from 3GB to 4GB kept 1 original RAM and whatnot...............
I popped in a new HDD and a 2GB Chip replaced the 1GB
Took out a Samsung HM250HI replaced with a Western Digital WD2500LPVT
I cloned the Recovery partition with no avail ( got the error )
I wiped the new HDD and used OEM Disk installed VIA Disk, got the error, then I Mounted it to a USB and got the same error, Ran long diagnostics on the New HDD and came back clean, ( extremely frustrated at this point ) posted here, and just waiting to try things.
As I am typing this I think I may have just found the issue, ( gonna swap the HDD maybe???? )
Will update in 20 minutes.
Old 03-20-2013, 03:35 AM
Good deal. Could be the hdd, perhaps slave it and check it with Crystal Disk Info either before or after the fact.
Review this thread too, if no joy in swapping the hdd:
http://www.sevenforums.com/installat...first-use.html
Wherein you look at the setup logs and see what gives.
Old 03-20-2013, 03:43 AM
what do you know, I put in a used HDD and the thing installed smooth as butter???????????????
Used HDD that works - Western Digital WD1200BEVS
I popped in the New HDD WD2500LPVT into an Acer Aspirer v5 and it installed 7 smooth as butter as well.
any suggestions on why it will not boot into the Compaq?
IDK just glad its fixed for now, got to go out and get new HDD
Goodnight Technibble
Old 03-20-2013, 04:54 AM
Glad you got a handle on it!
BIOS update needed or Setup is picking the wrong driver on the CQ? Have a good night. You earned it!
  #9
Old 03-20-2013, 02:14 PM
brandonkick brandonkick is offline
brandonkick will become famous soon enough
As stated in some other threads, HDD diagnostical software isn't 100% reliable.
As to why that new drive works in one machine and not another? All I can assume is what has already been stated. BIOS needing updated or setup not using correct driver for whatever reason.
I don't know.
  #10
Old 03-20-2013, 06:01 PM
tlaybourn tlaybourn is offline
tlaybourn is an unknown quantity at this point
Maybe due to Advanced Disc Format drive?
Had similar issues recently, had to install latest Intel RST driver at W7 install time (the old F6 routine).
Couldn't use restore partition as no way of loading driver.
In my case I got an error "could not install configure Windows on this computerís hardware".
See http://support.microsoft.com/kb/2466753
