Old 11-14-2012, 04:13 PM
greenfx greenfx is offline
greenfx is an unknown quantity at this point
Default Does a laptop's LED LCD has an inverter
There is a HP laptop which I have been trying to fix. The laptop has been dropped and has a fuzzy display. The display is perfect on an external monitor. So, I got a new LCD but the result is the same. Again, got a lcd cable but in vain
What could be bad on this laptop ? Some video controller on the mainboard ?
My final question - does LED LCD has an inverter ?
Old 11-14-2012, 04:20 PM
brock029's Avatar
brock029 brock029 is offline
brock029 is an unknown quantity at this point
Well an LED screen does not use an inverter but an LCD screen does.
Old 11-14-2012, 04:26 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has a spectacular aura aboutMartyn has a spectacular aura about
Before you go any further, test the hard drive if the laptop has been dropped. I made a mistake 2 years ago and replaced the cracked screen only to find the laptop hard drive was damaged when it was dropped. Fortunately the client went with the full repair otherwise I could have ended up out of pocket.
As regards the problem, if you replaced the screen and cable I would have thought you had it covered. Post a picture up if you can.
Old 11-14-2012, 04:32 PM
I will post the pic later. The model is HP Pavilion dv7-6c95dx.
Other than the fuzzy display, everything is perfect on this laptop - even the display on the external monitor.
Old 11-14-2012, 04:48 PM
anth anth is offline
anth is an unknown quantity at this point
Had a similar issue in the other week, after trying two different screens, I decided that at this point it was a mother board issue because there really was not anything else it could have been, external was fine hard drive was fine.
When a laptop is dropped, sometimes all the damaged is not visually seen.
Old 11-14-2012, 05:01 PM
seedubya's Avatar
seedubya seedubya is offline
seedubya has a spectacular aura aboutseedubya has a spectacular aura about
Sorry to be pedantic but there's some terminology confusion going on here....
There are two common types of Liquid Crystal Displays (LCDs). They are usually referred to by how they are backlit either by Cold Cathode Flourescent Lamp (CCFL) or by Light Emitting Diode (LED). The CCFL type is older and requires an inverter to supply alternating current (AC) from a direct current (DC) source at high enough voltage, the LED type is newer and does not require an inverter to operate since it utilises DC.
Old 11-14-2012, 05:02 PM
GeeksInKhakis's Avatar
GeeksInKhakis GeeksInKhakis is offline
GeeksInKhakis is on a distinguished road
There could be damage to the connector on the main board, where the LCD cable plugs in. If the display it's good on external, seems like the video controller is ok. If you tried a new cable and screen, that is all that's left.
Not exactly the same, but I had one where the main board connector plug got tweaked, the cable wasn't connected, but appeared to be.
"Your Neighborhood Computer Service Center"
Geeks in Khakis - Computer Service, Repair, Parts, & more
Old 11-14-2012, 05:06 PM
Maybe, the confusion arose because I put two questions.
I assumed that LED displays don't have an inverter. I wanted to confirm that from you folks.
Secondly, I wanted your advice as to what could be the reason for this fuzzy display.
Hope this makes it clear now.
  #9
Old 11-14-2012, 05:09 PM
okay, here's the display ... fuzzy display !
  #10
Old 11-14-2012, 06:28 PM
Is it the right resolution for the display? Looks 'stretched'.
