It's an ATI Radeon 9550 AGP. I installed Catalyst version 6.8.
I finally figured out how to disable my onboard graphics and everything is installed correctly, but my screen is "shaking". I changed the AGP Voltage setting in BIOS to 1.7 because someone at VIAarena.com in the forums said that would help stop my game from freezing but it is still freezing. The game is Black and White 2. Here is all the information about my computer I can find. Field Value CPU Properties CPU Type AMD Sempron, 1800 MHz (9 x 200) 3100+ CPU Alias Venice-256 S754 CPU Stepping DH-E6 Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3 Min / Max CPU Multiplier 4x / 9x L1 Code Cache 64 KB (Parity) L1 Data Cache 64 KB (ECC) L2 Cache 256 KB (On-Die, ECC, Full-Speed) CPU Physical Info Package Type 754 Pin uOPGA Package Size 4.00 cm x 4.00 cm Transistors 68.5 million Process Technology 11Mi, 90 nm, CMOS, Cu, SOI Die Size 84 mm2 Core Voltage 1.100 - 1.450 V I/O Voltage 1.2 V + 2.5 V Maximum Power 67.0 W CPU Manufacturer Company Name Advanced Micro Devices, Inc. Product Information http://www.amd.com/us-en/Processors/...30_118,00.html CPUID Properties CPUID Manufacturer AuthenticAMD CPUID CPU Name AMD Sempron(tm) Processor 3100+ CPUID Revision 00020FC2h Extended CPUID Revision 00020FC2h AMD Brand ID 0987h (Sempron 3100+) Platform ID CCh (Socket 754) IA CPU Serial Number Unknown HTT / CMP Units 0 / 1 Motherboard ID 12/07/2005-K8M800-8237-6A7L1G04C-00 Motherboard Name Unknown Front Side Bus Properties Bus Type AMD Hammer Real Clock 200 MHz Effective Clock 200 MHz HyperTransport Clock 800 MHz Memory Bus Properties Bus Type DDR SDRAM Bus Width 64-bit Real Clock 201 MHz (DDR) Effective Clock 402 MHz Bandwidth 3214 MB/s Chipset Bus Properties Bus Type VIA V-Link Bus Width 8-bit Real Clock 67 MHz (ODR) Effective Clock 533 MHz Bandwidth 533 MB/s Physical Memory Total 511 MB Used 365 MB Free 145 MB Swap Space Total 1150 MB Used 428 MB Free 722 MB Virtual Memory Total 1662 MB Used 822 MB Free 838 MB SPD Device Description DIMM1: Melco (512 MB PC3200 DDR SDRAM) Memory Module Properties Module Name Melco Serial Number None Module Size 512 MB (2 ranks, 4 banks) Module Type Unbuffered Memory Type DDR SDRAM Memory Speed PC3200 (200 MHz) Module Width 64 bit Module Voltage SSTL 2.5 Error Detection Method None Refresh Rate Reduced (7.8 us), Self-Refresh Memory Timings @ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS) @ 200 MHz 2.5-3-3-8 (CL-RCD-RP-RAS) @ 133 MHz 2.0-2-2-6 (CL-RCD-RP-RAS) Chipset Device Description: North Bridge: VIA K8M800/K8N800 North Bridge: AMD Hammer IMC South Bridge: VIA VT8237 North Bridge Properties North Bridge VIA K8M800/K8N800 Integrated Graphics Controller Graphics Controller Type VIA/S3 UniChrome Pro Graphics Controller Status Disabled AGP Controller AGP Version 3.00 AGP Status Enabled AGP Device ATI Radeon 9550 (RV350) AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Supported, Enabled Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name VIA Technologies, Inc. BIOS Properties BIOS Type Award Modular Award BIOS Type Award Modular BIOS v6.00PG Award BIOS Message K8VM800M-R2 FD System BIOS Date 12/07/05 Video BIOS Date 05/04/13 BIOS Manufacturer Company Name Phoenix Technologies Ltd. Product Information http://www.phoenix.com/en/products/default.htm BIOS Upgrades http://www.esupport.com/biosagent/in...m?refererid=40 Display Video Adapter Properties: Field Value Device Description RADEON 9550 Adapter String RADEON 9550 BIOS String 113-A03523-103 Chip Type ATI RADEON 9550 AGP (0x4173) DAC Type Internal DAC(400MHz) Installed Drivers ati2dvag (6.14.10.6606) Memory Size 256 MB I'm using EVEREST Home Edition 2.20 for the system info. |
Does the freezing only occur in Black and White 2? or most other games as well?
Owner and Founder of Technibble - If you have a problem with any user, they are flaming/being elitist/making snide comments etc.. Press the report button which is on the top right of every post. This will highlight the post in an admin area for staff to see and deal with. For adminly tasks such as username changes, moving threads etc.. please contact Martyn Check out Technibbles twitter: http://www.twitter.com/technibble |
that's the funny thing, it's only Black And White 2..but then, that's the only game I have that you need the cd to play it. I have CakeMania and Pizza Frenzy and a few other Shockwave/PopCap/GameHouse games and they are all full screen and I've had no problems at all with them, I left CakeMania running all night, and went back to it in the morning and finished playing with no problems.
| Thread Tools | |
| Display Modes | |
