#21
What these more experienced cablers are saying is true about Cat6. You must determine up front if you are going with 100-Mb or GigE because they do require different procedures, patch panels, connectors, wire, and sometimes different tools. It can be frustrating and wasteful to install Cat6 then find that it does not test much better than 100-Mbs.
Not reusing punch panels sounds like a warning from the people selling the panels. In the Bell System network where I was a Central Office Switching Engineer, we reused the same connection many times with no problems. I suspect this may apply more to environments with corrosive atmospheres but not a typical office. Last edited by sys-eng; 07-06-2012 at 12:56 AM. Reason: spelling |
#22
I second StoneCat, it is B all the way. I wire everything B and find that almost everything is wired B.
#23
Chris Sprinter Technology Services 24/7 onsite service for the upper midwest. Retail stores in Stevens Point and Wausau NOW OPEN! www.SprinterTech.us www.Facebook.com/SprinterTech Discounted wholesale printing for TN members! 1,000 4/4 biz cards $29.99 promo code: technibble Vinyl Banners, Magnets, Brochures, Post Cards, Stickers, Rack Cards, Window Perf and MORE! PM for quote! |
#24
Just use B for any new installs and match what they have got on existing installs. I doubt hardly anyone uses A, but if they do match it for that job.
The bailing wire is a great idea as is pulling in some pull string to do more pulls (especially if you have conduit). That said, never do two (2) drops instead of one (1)... unless they are paying for two drops. If you do, they will probably forget all about you and then contract with another company that will determine the cable is already there and charge them a full $150 to $200 for the drop, which will take 5 minutes to terminate, test, and label being the cable is already there. Yeah... Do the service loops, too. Make sure you have fiberglass fish rod, and remember metal construction is EASIER than wooden construction! With metal you just feed it down the hollow wall and are good to go. With wood, you keep hitting fire-breaks and have to cut sheet-rock (carefully to be easily patched) drill a hole, and feed the cable through it... This takes a LOT of time... Plus you have to glue or tape and sometimes sand/paint to get rid of the access hole you cut for sheet rock on wood... Then there is BRICK, which is the worse because all you can do is drill a hole through it and fish the cable... Then you have to run tons of cable runner and get all the end caps, inside/outside corners, 90 degree bends... joiners, etc. To me cable runners look bad though they are a TON better than just running cable on the wall. Regardless, you now have enough tips to do the job. Just make sure it looks good, is easily serviceable in the future, supports future bandwidth (i.e. CAT6 vs CAT5), that you are legally allowed to do the work, and that it is up to code. I don't like seeing shortcuts everywhere! Last edited by NETWizz; 07-05-2012 at 08:26 PM. |
#25
All great tips and much appreciated and very helpful. Couple of questions:
1) What is a service loop? 2) Does anyone know if plenum rated cable is required in Mass for above drop ceilings? (its quite a bit more expensive than riser) (I assume it is) |
#26
2: It all depends on the building, - check whether it's an air return or not.
#27
#28
#29
30 ft !! Wow!!
Mine have a solid spring-steel rod. Yours must be more fancy than that. You would have to have a camera that far away to avoid drilling the wrong place. |
#30
| Thread Tools | |
| Display Modes | |
