Old 06-18-2012, 05:40 PM
732914TECH 732914TECH is offline
732914TECH is an unknown quantity at this point
Default internet explorer 100% cpu
Having an issue with a bunch of customer's machines, all Windows XP, either IE 7 or IE 8, Pro or Home does not matter. Ive had 5 this week where when they access a website other than something like google the CPU usage and memory jacks up really high to 100% and the whole machine becomes slow obviously. Ive tried multiple things, reinstalling IE, running SFC, uninstalled Flash and Java, reset IE to default settings, disabled everthing in startup using MSconfig, with no result. Has anyone else had this problem? And no its not a hardware problem, it seems to be a software problem maybe a recent update?
Old 06-18-2012, 06:37 PM
I FIX PC'S's Avatar
I FIX PC'S I FIX PC'S is offline
I FIX PC'S is an unknown quantity at this point
Have you done the obvious and looked at CPU usage to see what's eating it up?(all users).
Old 06-18-2012, 06:47 PM
iisjman07's Avatar
Do they all have antivirus software installed or are they infected?
Old 06-18-2012, 06:49 PM
Xander's Avatar
Xander Xander is offline
Xander is a jewel in the roughXander is a jewel in the roughXander is a jewel in the rough
No mention of trying IE in "No Add-on" mode.
Xander St Catharines Computer Repairs
New here? Watch this and read this. Remember, it's not our problem, it's yours so ask your questions well.
e.g. Make/Model#, Win version/SP#, BSOD 0x#. Consider posting Event Viewer logs, Autoruns exports or Speccy reports.
More info means better answers and less snark.
Don't be parasitic and only pose your own questions. Help others.
D7 question/idea/etc? Bring it to the D7 Forums.
Old 06-18-2012, 06:55 PM
Yes ive looked into what file was causing it using processor explorer and it was ieframe.dll, i tried IE no addon mode with the same result, and ive ran all my virus scan programs i can think of, it only happens with XP. I believe an update caused it, ive uninstalled the last IE update that was installed but did not help.
Old 06-18-2012, 11:42 PM
johnrobert's Avatar
johnrobert johnrobert is offline
johnrobert is on a distinguished road
Did you run combofix
Might not fix this problem, but generally great for IE problems
Old 06-19-2012, 01:37 AM
tf76's Avatar
tf76 tf76 is offline
tf76 has a spectacular aura abouttf76 has a spectacular aura about
http://support.microsoft.com/fixit/
Regards,
Old 06-19-2012, 01:26 PM
Yes I have ran Combofix on one of the machines with no result.
  #9
Old 06-19-2012, 01:31 PM
Originally Posted by tf76 View Post
Ill try some of those out and report back, Thanks
  #10
Old 06-19-2012, 03:44 PM
johnrobert's Avatar
Go as far back with system restore as you can
I always do it manually it only takes a few minutes to do and never comes back your system cannot be restored
Make a copy of config folder first then you can undue it
