Hello all. I have an HP Probook 4510s on the bench.
Specs: 4 GB DDR 3 RAM Intel core 2 duo 250 GB Hitachi HDD I ran an extended self-test with gsmartcontrol on the HDD it passed. I have been unable to test any other components as you will see below. Customer informed me that the machine wouldn't properly power on. The first thing that I did was test the AC adapter with my meter and the output was what it should be. I noticed that the power LED was not lit when the AC adapter was plugged in. The next thing I tried was turning the machine on myself with the battery connected (no AC adapter). The blue ring around the power button turned blue for a few seconds then went dark. I didn't see anything on the screen at all when the blue light was lit. Next, I took the battery out and tried to power on with the AC adapter plugged in. I pressed the power button and got absolutely nothing. No blue light like when the battery was connected. My troubleshooting thus far led me to believe that the machine may have a faulty DC jack so I tore the laptop down and pulled out the jack and tested it with my meter with the AC adapter plugged in. The output was what it should be (19.2v). At this point I am stumped. My instinct tells me I may have a bad mobo on my hands but I am still a beginner and I don't trust my instincts all that much just yet so I figured that I'd reach out to my fellow techs. I plan on swapping the RAM for known good but I don't think that is the issue considering I didn't get any beeps or video output that would indicate that it was a RAM issue. One of the board's caps looks ever so slightly more bulgy than the other three but I'm not sure. Thanks in advance for any help/replies.
I hate the newer HP jacks. Too many pins and like on this one you have TWO harnesses, one is a 4 wire and the other is the smaller 3 wire.
If this thing is totally dead, why not hot air it and see if it comes back to life. I'm not saying it will be fixed but if they board is dead you can play with it just for future reference. |
I tested for power on the four wire harness only. Should I test the three wire harness as well? As far as hot airing the board...I don't have a gun or a rework station. I plan to get one (station) though.
#9
I just re read my OP and I def wasn't clear enough. I was referring to the light on the jack itself.
#10
I have to wonder why the laptop makers like HP and Dell just keep changing everything, making jacks so complicated and when something fails nobody really has a 100% way of knowing what the hell to do next. If Sony, Acer, Gateway and other can use two or four wire simple jacks why does HP/Compaq and Dell have to keep expanding. Have you seen the 11 and 13 pin jacks on some newer models ? Somebody tell me why the hell they exist ? |
| Thread Tools | |
| Display Modes | |
