Old 05-22-2012, 04:59 PM
shamrin shamrin is offline
shamrin will become famous soon enough
Default Can I call this a failed motherboard now?
I really do hate these probable mobo failures, seems you can never identify them deductively unless you've got popped caps or something. Anyway...
This is an HP desktop running XP. The symptom is that it spontaneously reboots from Safe Mode and Normal Mode at boot time. No dumps.
  • Tested RAM w/ Memtest - OK
  • Swapped sticks, changed RAM sticks
  • Ran Video RAM Test Boot disc - OK
  • Switched from onboard graphics to a PCI-E card
  • Tested HDD outside of computer using Seatools (could not use Seatools on host machine as keyboard and mouse would not respond)
  • Pulled plug on optical drives
  • Swapped PSU
  • Boot to F4UBCD (XP environment) - No mouse cursor on screen, no keyboard worky
  • Boot to Ubuntu - V. slow boot (10 mins) then very slow operation trying to open C: drive (gave up waiting)
  • Boot to MRI-type test environment, runs for 1 hour then freezes when tech tries to change view on HDD test screen
  • Boot to ERD environment - Fails whilst loading Windows (progress bars freeze)
I think we're down to the motherboard but it just won't fail in some satisfying way that I can ID. Any further suggestions or should I just put a fork in it?
Hartland Computer Services, Lexington, Ky 40515
(859) 536-4107
www.CrosbyDrive.com
Old 05-22-2012, 06:03 PM
Mr.Mike Mr.Mike is offline
Mr.Mike is an unknown quantity at this point
Have you checked the BIOS settings? It's difficult to think about anything else without a little more information. What model HP?
Old 05-22-2012, 06:14 PM
BDNTech BDNTech is offline
BDNTech is an unknown quantity at this point
Default Try this
assuming the hdd checked out ok change the cable for the hdd and reset the bios by taking out the cmos battery holding the power button in for 10secs and putting the battery back in.
Old 05-22-2012, 07:50 PM
Good suggestions. I thought briefly of both of these but I couldn't figure out how they related to my problem. Anyway, have now tried them both, alas to no avail.
Subsequently I tried booting it to the installed Recovery Console (black screen) then to an XP boot disc (USB keyboard stops working in install environment, machine runs super-slow with PS/2 keyboard). It's the flipping motherboard.
(859) 536-4107
www.CrosbyDrive.com
Old 05-22-2012, 10:18 PM
PCX's Avatar
PCX PCX is online now
PCX is a jewel in the roughPCX is a jewel in the roughPCX is a jewel in the rough
Its really hard not to say its failing isn't it? How long did you test the memory for and what did you use to test the MOBO?
_
Before you decided to post your problems on the forums, did you run a FULL diagnostic?
Be willing to do what your competition is not.
"The smartest and most successful people in the world are those who surround themselves with smarter and more successful people than themselves"
Old 05-23-2012, 12:01 AM
The only (practical) way I know of to identify a motherboard problem is by induction (test every other component and if they are all OK, it must be the motherboard, or as Sherlock Holmes said, "...when you have eliminated the impossible, whatever remains, however improbable, must be the truth..."). Alas, this method is probabilistic and you can never know for sure if you are right.
I only ran through a couple of iterations on the RAM test, but I switched to different RAM as well and caught the same issues.
(859) 536-4107
www.CrosbyDrive.com
Old 05-23-2012, 01:52 AM
katz katz is online now
katz is an unknown quantity at this point
Did you test the CMOS batt. voltage? I've seen low voltage batt. cause flaky things...
Nothing to see here... :(
Old 05-23-2012, 04:10 PM
indyvirusguy indyvirusguy is offline
indyvirusguy is an unknown quantity at this point
I would say it is the motherboard.
  #9
Old 05-23-2012, 04:24 PM
crashtech crashtech is offline
crashtech is an unknown quantity at this point
I guess the only thing left to do is yank it out of the case and test it on the bench, since the next step is to change it anyway. Once in a while the way it is mounted, or a foreign object caught under the board can cause a problem, although it's very unlikely.
  #10
Old 05-23-2012, 05:27 PM
altrenda altrenda is offline
altrenda will become famous soon enough
troubleshooting words to live by.
When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
Sherlock Holmes
