I'm still an amateur when it comes to electrical and haven't come across this yet on a desktop so I thought I'd ask anyone with more experience.
My few experiences with laptops suggest that simply closing the circuit for the power switch with a jumper is enough evidence to diagnose a bad switch if you don't own a multimeter. I know I can simply test this in the shop tomorrow and I plan to, but I thought I'd post about it as well while it's on my mind. I just realized that as much as I like to say a failed CPU is the rarest thing you'll find I think on desktops a failed switch is even more rare. I've replaced a handful of cpus over the years but 0 switches on desktops, and less switches on laptops after I (accidentally) took one apart and saw the corrosion that was preventing the metal cap from closing the circuit. Last edited by Tepin; 05-16-2012 at 04:22 AM. Reason: Bad gramma. |
Please EMAIL member support queries "Do something you love, and you'll never work a day in your life" |
I've replaced power buttons on about a dozen dell studios and gateway nv53 laptops. Buttons on the hinge is one of the dumbest ideas I've seen in computers. Granted these are usually the mount rather switch being broken, but I have seen a number of actual failed switches.
You might want to invest in a multimeter. Nothing special, just a cheap little job for testing continuity, power supplies, cables, etc. I don't care about accuracy as much as confirmation I'm on the right track troubleshooting.
It's easier for me to check to see if a voltage is there or if a switch works than guess or do some workaround. Just another diagnostic tool to help do a better job.
When you have eliminated the impossible, whatever remains, however improbable, must be the truth. Sherlock Holmes |
I think laptop chassis are designed by insane people locked away in a lunatic asylum somewhere. |
I agree wholeheartedly.
They seem to be mostly engineered to be assembled more efficiently rather than repaired efficiently. I do like what Apple has done since 2008 with the unibody laptops. They've actually provided the schematics in the service manuals for shorting the logic board to start the machine in the case of a stuck power button or blown switch. Makes them easy to troubleshoot. On the other hand, a repair is an entire top case/keyboard replacement (minus trackpad) and a complete tear down.
[FONT=Arial]ACMT[/FONT] Quote:
#9
+ 1 for the laptop design asylum.
I've had two late model dells recently that required complete teardown to access the hard drive. The drives are screwed to the bottom of the motherboard, with no access through the bottom of the case. ![]() Both were under warranty, and I wanted to image the drives before the warranty repair. Completely reassembling a non-working computer just so the warranty guy can tear it apart again is maddening. |
#10
Yeah, pick up a $20 multimeter from the hardware store. It's a handy tool to have around the shop
| Thread Tools | |
| Display Modes | |
