Old 05-14-2012, 08:47 PM
katz katz is online now
katz is an unknown quantity at this point
Default Questions about internet - Powerline Adapter Kits
Client wants internet in a second room, running cable is not an option. I have been considering a powerline adapter kit, such as the TrendNet -
http://www.amazon.com/TRENDnet-Power...7028301&sr=8-1
Years ago I heard that they needed to be on the same circuit in order to work. Is this still the case, or will they work on independent circuits?
Any other suggestions? Options?
Thanks!
Nothing to see here... :(
Old 05-14-2012, 09:16 PM
Xander's Avatar
Xander Xander is online now
Xander has a spectacular aura aboutXander has a spectacular aura about
The ones I have, and use, specify that they need to be on the same circuit. It makes perfect sense, of course, otherwise there is no way that the signal could complete.
Xander St Catharines Computer Repairs
New here? Watch this and read this.
Remember, it's not our problem, it's yours so ask your questions well.
Old 05-14-2012, 09:40 PM
cprompt's Avatar
cprompt cprompt is online now
cprompt is on a distinguished road
Actually, I'm not sure they need to be on the same circuit. I had a set that I ran through a circuit panel, to a sub-panel in an attached building, so the signal passed through at least 3 circuit breakers. It gave me no problem that I was ever aware of - speed did not seem to be impacted, I didn't have issues with dropping the signal, etc.
I don't know whether the signal travels on the hot line or on the neutral line. If it travels on the neutral line, then they are all connected right in the circuit breaker box. If it travels on the hot line, then there still is a connection through the circuits, otherwise the electricity could not go through.
That's my experience, at least - I'm certainly no expert!
Brian.
Old 05-15-2012, 12:45 AM
C.Quill C.Quill is offline
C.Quill is an unknown quantity at this point
Would something like that work in a Condo/Apartment?
I've never heard anything specific about whether they work or not and how they work.
Firefly Solutions LLC.
Computer Repair & Technology Consulting
Providing computer repair to Siesta Key, Sarasota, Bradenton, and Longboat key, FL
Old 05-15-2012, 01:09 AM
Every thread/post I read on the net is split on the idea; some posters say they need to be on the same branch circuit, others mention that they have no problems at all in huge house set-ups...
I guess the only way to know for sure is to try it in your particular situation...if it works, it works. If not, guess the only alternative is to run cable or go wireless.
Old 05-15-2012, 01:35 AM
Tepin Tepin is offline
Tepin is on the way
God I remember trying to support these 8 years ago at 2Wire .. they stopped selling the product it is to much of a headache.
Basically it goes like this:
There isn't anyway to know for sure if it will work or not until you try it. They should work as long as all outlets are on the same panel. They don't have to be on the same breaker. Being on the same panel is still not a guarantee that they will work unfortunately. The only way to know for sure is to try it.
My suggestion would be the obvious one, use wifi instead.
Old 05-15-2012, 01:51 AM
rsarceno's Avatar
rsarceno rsarceno is offline
rsarceno will become famous soon enough
Why not set up WIFI?
Old 05-15-2012, 01:56 AM
The powerline adapters looked like a less expensive option at around $50 for a set. They (customer) have no router, which means the cost of a router & receiver.
But, it looks like we will be going with Wifi after all, as I would rather not deal with the hassle of these powerline things if they are as "iffy" as they seem to be.
  #9
Old 05-15-2012, 03:19 AM
Tepin is on the way
Are you in the US?
You can get an inexpensive router and a couple of adapters for around $50-60 on Newegg. I suggest you stay away from Rosewill and refurbished adapters; personally I've found the Encore ones to be the most reliable in the $10 range.
  #10
Old 05-15-2012, 09:53 AM
YeOldeStonecat's Avatar
YeOldeStonecat YeOldeStonecat is online now
YeOldeStonecat is just really niceYeOldeStonecat is just really niceYeOldeStonecat is just really niceYeOldeStonecat is just really niceYeOldeStonecat is just really nice
I've had no problem with them on different circuits within the same building. I have 3 circuits in my house that has multiple buildings on the same log..and it works no problem. "Copper beats wireless" any day of the week for me.
Manufacturers are gunshy to support all different types of wiring...having different circuits in the same building can potentially complicate things, so I support they draw the line somewhere by saying "must be on same circuit". The issue is really when you go to circuits on different "phases". This is not common.
Resident "Geek on a Harley" doing IT in Southeast Connecticut
http://www.dynamic-alliance.com/
https://www.facebook.com/YeOldeStonecat
