Thread Tools | Display Modes |
Hi,
I have a Dell Inspiron M5030 here which does not charge, the laptop is in full working order apart from that. I have replaced the DC jack to no avail, I am pretty much at a loss as to where the fault could lie, there are no obvious damaged components on the board. Any help would be appreciated. Thanks, Ian
http://www.adeptpcrepair.co.uk - Laptop Repair Cardiff |
does it say plugged in not charging in windows? if so its probably a bad ac adapter. the center pin is not working correctly and allowing the laptop to charge the battery
I've tried my universal adapter and its the same. No, it doesnt say plugged in, its as though there is no charger connected at all.
ah ok id say theres a blown fuse somewhere near the dc jack then. is the dc jack on a seperate PCB ?
Unfortunately not on this pcb. I would have just bought the daughterboard to save hassle otherwise.
I'd rather go the smd replacement route than replace the board, i've already placed a blob of solder over what looks like the fuse to no avail, the laptop still powers via battery.
I have the same problem on a 6040 PP20L - it's a bad Ram controller, and only option is a mobo replacement unfortunately...... at least for me I could get the charging lights to work if I had both Ram sticks out, it would work great (well except it wouldn't boot with no ram) but as soon as any ram was installed, BAM doa!
Chris Sprinter Technology Services 24/7 onsite service for the upper midwest. Retail stores in Stevens Point and Wausau NOW OPEN! www.SprinterTech.us www.Facebook.com/SprinterTech Discounted wholesale printing for TN members! 1,000 4/4 biz cards $29.99 promo code: technibble Vinyl Banners, Magnets, Brochures, Post Cards, Stickers, Rack Cards, Window Perf and MORE! PM for quote! |
Jumping components at-will usually has ill consequences.
Aaron Heidlebaugh Computer Technician / Owner www.AaronsPCSupport.com 804-307-4465 (Call or Text) Laptop LCD repair | DC Power Jack Repair | Virus Removal Desktop Repair | Hardware | Software | Troubleshooting |
I do have a multimeter but find it a load of tosh tbh, I have found an apparant faulty mosfet in the past, replaced it only to find it not to fix the problem.
The fuse i jumped is definitely a fuse due to the label on the board, its just whether it is a fuse for the dc jack, though it must be, thinking about it. My multimeter shows 19v from my universal charger going through the board, which confuses me. How can a ram controller cause a motherboard not to charge? I didn't even think they were linked?
#9
Are you sure you got all the pins soldered in good? Just remember, a motherboard has several layers in which the pins may have to make contact, so simply checking the voltage on the soldered side may not always yield accurate results, especially if the solder hasn't flowed completely through.
#10
I am sure it is all soldered well. The original jack looked undamaged, only replaced it out of routine.
| Thread Tools | |
| Display Modes | |
