Go Back   Technibble Forums > Operating Systems > Linux
Old 04-26-2012, 11:32 PM
compnet compnet is offline
compnet will become famous soon enough
Default reset ubuntu passwords
This one is killing me.. I've tried everything google has to offer to no avail..
I've tried;
booting to recovery = doesn't work because it has root password
booting to single user (replace ro with rw and add init=/bin/bash on kernel line) = Authentication token manipulation after passwd command and password is unchanged
so reading up on the token error, I tried mount -o, remount, rw / (also added -n) = same token error
Then tried booting from the live cd, and doing chown, and I'm getting the same token error..
The only thing I haven't tried is some googling mention comparing /etc/password and /etc/shadow, but the don't go into any detail of what to compare or how to actually do it..
I'm mostly a linux noob, about to throw in the towel..
Old 04-27-2012, 12:36 PM
rjframe rjframe is offline
rjframe will become famous soon enough
Boot a livecd or slave the drive to another PC. Find and open /etc/shadow (make a copy first). It will have a list of entries that look something like this:
username:$6$QR3drPrQ$JLolPKyiVuXvea1F2IpbPx9F9PEV0 s/IGcNCpm6ZrBA6AFDvwHPQG7EsTQHuUqxfCvlsuKRb.O7w5RLPy j8nS/:15129:0:99999:7:::
The random-looking text between the first and second colons are your password. Find the user you want, then delete the password:
username::15129:0:99999:7:::
Reboot the PC.
I am not absentminded. It is the presence of mind that makes me unaware of everything else.
G.K. Chesterton
Old 04-27-2012, 03:53 PM
iisjman07's Avatar
Reboot the PC.
Nice tip, thanks for sharing
Old 04-30-2012, 06:10 PM
Finally got back around to this one. there are 2 partitions, one has all the system files, the other has all the username folders. on the system partition there is no shadow folder or password folder in the /etc folder.
I'm just gonna give the computer back. I think the user either took measures to prevent normal password resetting procedures from working, or the install is somehow corrupt.. I've spent way too much time on this already.
Old 04-30-2012, 08:21 PM
codegreen codegreen is online now
codegreen is a jewel in the roughcodegreen is a jewel in the roughcodegreen is a jewel in the rough
/etc/passwd (note the spelling) and /etc/shadow are not folders; they are text files. How did you look for the files? Did you boot from a livecd? If so, did you remember to mount the hard drive and look for the files there?
Stephen Gilbert
Code Green Technology:
Fredericton Computer Repair
Old 04-30-2012, 08:40 PM
:facepalm:
Next problem, I don't have permissions to open the shadow file... Also, what would I open them with on an ubuntu live cd?? open office?
edit:
typing mount in terminal give me this for the partition I'm looking at
/dev/sda6 on /media/(hash) type ext2 ( rw,nosuid, no dev,uhelper=udisks)
Old 04-30-2012, 08:47 PM
Slaters Kustum Machines's Avatar
Slaters Kustum Machines Slaters Kustum Machines is offline
Slaters Kustum Machines is on a distinguished road
:facepalm:
I use gedit in Ubuntu ie: "sudo gedit /etc/filename"
Old 04-30-2012, 08:54 PM
Thanks, on the live cd that opens the live cd shadow file.. I went to /media/(hash)/etc and did 'sudo gedit shadow' and it opened up blank, I'm assuming because of permissions
  #9
Old 04-30-2012, 08:56 PM
Blank generally means the file does not exist, it creates it, but is not saved unless you actually "save" it.
In /media/(hash)/etc do ls (lowercase L and S) and see if the shadow file is listed.
  #10
Old 04-30-2012, 09:24 PM
ah.. yes it is there, there is a dash after it "shadow-"
If I type it with the - it opens up and I can see the users... So do I just make a copy and then delete between the first 2 colons after the username?? Does the - have any significance? And I only have to do this with shadow, not in passwd?
