#11
[FONT=Arial]ACMT[/FONT] Quote:
#12
Yeah, you most definitely want a desktop with lots of airflow and and an open loading bay. I got a bunch of these that gives the drive plenty of room to breath as well as lots of air flow in a full size case. That said, I find it harder to connect a failing hard drive via USB vs a SATA controller in most cases due to the reasons you listed above. It just makes the computer run like junk and the other hard drives also have a harder time connecting if on the same SATA controller, which is one of the reasons why I have more than one. Its also a good idea to have a decent processor as well. Testing multiple hard drives (especially if some are failing) or cloning them will soak up the processor pretty quick. I personally use an AMD Phenom II Quad Core Processor in my rig.
_ Before you decided to post your problems on the forums, did you run a FULL diagnostic? Be willing to do what your competition is not. "The smartest and most successful people in the world are those who surround themselves with smarter and more successful people than themselves" |
#13
Do I understand you correctly?... you use a motherboard in your bench system that has two on-board sata controllers (many newer motherboards have a separate controller for Sata 3Gb and Sata 6Gb) or you use an add-on sata controller pci or pci-e card to attach the second hard drive to.If this is the case, I will check out my several bench systems and add the cards if needed. I've never given this a second thought. I've just got extra long Sata cables and Ide cables hanging out of the open case and attach the drives, with the drives standing on end to get as much air flow through them. Thanks for this tip, it's a good one.
#14
#15
#16
#17
Thanks for the useful tips, PCX! I will stick to SATA bays.
#18
I'm not trying to hijack this thread but,
Can anyone recommend a decent front loader? Thanks in advance! |
#19
http://www.amazon.com/gp/product/B00...00_i00_details
#20
| Thread Tools | |
| Display Modes | |
