Hi, is there some driver I should loading before a clean install to a amd quad core system?(phoenom 9150e) I'm installing vista home pre x64 to a new hard drive, the process took 2 hrs to install, and moves at a snails pace, no crashes just painfully slow, this thing has 5 gb ram and I already ran full diagnotics beforehand. Device manager looks fine, no ! I ran short smart test from the bios, clean weird, Something I missed?
_ Before you decided to post your problems on the forums, did you run a FULL diagnostic? Be willing to do what your competition is not. "The smartest and most successful people in the world are those who surround themselves with smarter and more successful people than themselves" |
1. floppy (disabled) 2 blank 3. blank 4. dvd 5. new hard drive Last edited by ell; 04-14-2012 at 05:28 PM. |
I'm not going to sell her a bad hd, just want to rule out the quick fixes first, it does appear to be a bad drive, but I would expect a crash not just slowness, I'm going to give bios defaults a shot. It runs fine in a live cd. |
I've experienced similar situations, and it's been the hard drive.
Crashes do not always equate to drive failures. Slowness, when everything else is ok to me means time to break out the testing tools. Better being safe and knowing the drives a ok or not. Rather than sending out the machine knowing that you've not quite done all the tests you could and the drive fails in a few weeks. How would that look to your client?
Hope this helps Be Safe Nige Cadishead Computers |
#9
ok, so I've run overnight FULL system diagnostics, all is clean, now I've just found this link and I'm pretty sure this is my issue, what a pain http://www.geek.com/forums/topic/ext...running-system and ofcourse I can't find a hp oem vista home premium 64 bit iso. I have put the old drive back in and am trying to make a recovery disk set, its already failed once. Whats a good clone program for bad disks? I already tried acronis, fail.
#10
Here is one other thought, I have a KVM switch with makes some computer (very very very few) run extremely slow, almost unusable. If you are using a KVM, try doing it without.
| Thread Tools | |
| Display Modes | |
