I tried Control Panel, Internet Options, Programs, E-mail as described in Yahoo Mail Help. Yahoo was not in my list of choices.
I reinstalled Yahoo Messenger. Still no change Where did I go wrong? Thanks for your help.
Hi
I'm assuming you mean to set up in Outlook Express. This is how I do it: These are the instructions for Outlook Express on a PC: Open Outlook Express, click [Tools] then select Accounts Click the [Mail] tab, then click [Add] and select Mail The wizard will start. Type in your name then click [Next] Enter your email address (yourname@btopenworld.com or yourname@btinternet.com) then click [Next] Enter the BT Yahoo! mail server address: mail.btinternet.com then click [Next] Enter your username and password then click [Next] Click [Finish] To complete the account creation process click [Tools] then select Accounts Click the [Mail] tab, then click [Properties] Click the My server requires authentication box to place a tick inside. Click [OK] Repeat the above process for each mail account you want to set up, including sub accounts. Each sub account will have a different email address and password. If you're having trouble sending email from Outlook Express (or other email software), it may mean you need to switch on SMTP authentication. |
Hi
I assume you mean to set up in outlook express. This is how I do it: These are the instructions for Outlook Express on a PC: Open Outlook Express, click [Tools] then select Accounts Click the [Mail] tab, then click [Add] and select Mail The wizard will start. Type in your name then click [Next] Enter your email address (yourname@btopenworld.com or yourname@btinternet.com) then click [Next] Enter the BT Yahoo! mail server address: mail.btinternet.com then click [Next] Enter your username and password then click [Next] Click [Finish] To complete the account creation process click [Tools] then select Accounts Click the [Mail] tab, then click [Properties] Click the My server requires authentication box to place a tick inside. Click [OK] Repeat the above process for each mail account you want to set up, including sub accounts. Each sub account will have a different email address and password. If you're having trouble sending email from Outlook Express (or other email software), it may mean you need to switch on SMTP authentication. |
If your using Yahoo's free e-mail then you will not get POP access and can only use their web interface to send/receive e-mails.
If your a paying subscriber, you can setup your mail client as detailed above and select the option to make it your default mail client. |
| Thread Tools | |
| Display Modes | |
